POV-Ray : Newsgroups : povray.beta-test : "inverted" said to be a keyword and is not Server Time
19 Dec 2025 09:50:21 EST (-0500)
  "inverted" said to be a keyword and is not (Message 1 to 4 of 4)
Subject: "inverted" said to be a keyword and is not
Date: 16 Oct 2001 15:33:46
Message: <3bcc8b9a$1@news.povray.org>
Section 6.7.12.6.1  Black Hole Warp
"If the inverted keyword is specified then the points pushed away from the
center instead of being pulled in."
Midway through the description.
On another point, this section and many others (another place is under
6.7.11.15 Function) are not blue fonts for the section number/name.  Seems
to be any that are a series of 5 or more numbers used.
Bob H.
http://webpages.charter.net/omniverse/omniverse.htm
Subject: Re: "inverted" said to be a keyword and is not
Date: 17 Oct 2001 03:53:35
Message: <Xns913D64A38B0EBseed7@povray.org>
> from the center instead of being pulled in."
Is it a POV-Ray bug, or should this line be removed from the doc?
Ingo
Date: 17 Oct 2001 04:54:04
Message: <3bcd472c@news.povray.org>
Seems like it should be "inverse", and "are" should be placed somewhere
in the sentence.
#macro C(X,Y)cylinder{X*x<X,0,-Y/2>.1}#end#macro U(R,X,Y)intersection{torus{.9
.1}box{-1 0rotate y*R*90}translate<X,0,Y>scale 1-z*.5}#end union{U(0,0,0)U(1,0
,0)U(2,-1,-1)U(1,1,0)U(1,1.5,-3)U(1,2,0)U(3,1,0)U(2,2,0)U(0,3,0)U(3,2,.5)C(.1,
2)C(.8,1)C(.8,-1)C(1.1,1)C(1.9,-1)pigment{rgb 10}rotate x*90translate<-1,0,4>}
Date: 17 Oct 2001 09:10:55
Message: <3bcd835f@news.povray.org>
"Elias Pschernig" <eli### [at] aonat> wrote in message
news:3bcd472c@news.povray.org...
> in the sentence.
Yep, 'inverse' is correct.  'inverted' doesn't exist.  And yeah, "points are
pushed away" sounds right.
Only place I can find the word used is as a parameter for the Circle_Text
macro in Shapes.inc.
Bob H.
