POV-Ray : Newsgroups : povray.beta-test : Bug in the installler [Win] Server Time
17 May 2026 12:28:14 EDT (-0400)
  Bug in the installler [Win] (Message 1 to 8 of 8)
Subject: Bug in the installler [Win]
Date: 14 Oct 2001 12:10:43
Message: <3bc9b903@news.povray.org>
POV-Ray 3.5b6 (and previous) Win98SE, PIII733, 160MB
If installed on the root of a drive, re-installing adds an extra backslash.
E.g. "d:\\POV-Ray for Windows 3.5" instead of "d:\POV-Ray for Windows 3.5".
The installer then fails since it cannot find that directory.
Michael
#declare R=<8,4,.6>/3;#declare C=function{pattern{object{text{ttf"crystal.ttf"
"MDJ"1,0translate-R/4}}}}camera{location-z*30}box{-R,R pigment{rgbf 1}interior
{media{emission.1density{function{C(x,y,z)}density_map{[0mandel 50color_map{[0
rgb 0][.2rgb x][1rgb x+y]}interior 1,1.5scale 60translate<-33.75,2.85>exponent
4][1rgb<2,2>]}}}}scale 24hollow}// (c) 2001 MDJohnson red### [at] wvadelphianet
Subject: Re: Bug in the installler [Win]
Date: 17 Oct 2001 04:00:58
Message: <3bcd3aba@news.povray.org>
"Redbeard (MDJohnson)" <red### [at] wvadelphianet> wrote in message
news:3bc9b903@news.povray.org...
I can't replicate this problem. Are you sure you didn't accidentally type in an
extra '\' ? (it gets the alternate path from you, not from the registry).
-- Chris
Date: 17 Oct 2001 22:37:08
Message: <3bce4054@news.povray.org>
"Chris Cason" <newsadmin-despam-@povray-no-spam.org> wrote in message
news:3bcd3aba@news.povray.org...
an
> -- Chris
I first installed beta 4 on this machine, and installed it off the root of the D
drive.  Every subsequent install of a new beta has filled in "d:\\POV-Ray for
Windows 3.5" for me.  The first time (beta 5) I questioned it but tried it
anyway.  When it started with the backup it failed (gracefully).  So I went back
and removed the extra slash.  When I installed 6 it did the same thing.  To test
it, I tried the install anyway.  It failed this time, too.  I installed it in
the default location on this machine, and have had no problems.  I can probably
try installing it off the root of another of the drives on this machine to see
if I can duplicate it.
Michael
PS - Great work!  3.5 is turning out to be very nice.
Date: 18 Oct 2001 13:22:04
Message: <3bcf0fbc@news.povray.org>
This is very strange - I default the location to %PROGRAM_FILES%\POV-Ray blah blah.
The only way the above could happen is if your system thinks that the default
'Program Files' directory is 'd:\'. And that could only happen if you have modified
it from the default (%PROGRAM_FILES% refers to the registry; this is a system-wide
setting not specific to POVWIN).
The installer does not ask the registry where the last version was installed so it's
not getting it from there.
-- Chris
Date: 18 Oct 2001 19:10:40
Message: <3bcf6170$1@news.povray.org>
blah blah.
default
That would explain the original problem: if %PROGRAM_FILES% = D:\, then
%PROGRAM_FILES%\POV-Ray = D:\\POV-Ray.
Date: 19 Oct 2001 00:19:13
Message: <3bcfa9c1@news.povray.org>
news:3bcf0fbc@news.povray.org...
the D
for
blah.
modified
system-wide
so it's
> -- Chris
I'll lay odds that's what it is.  I do have the D drive on that machine set up
as the program files directory.  Makes orginazation easier :-)  So, I should
probably change it to read D: instead of D:\.  I'll try it for the next beta.
Thanks!
Michael
Date: 29 Oct 2001 09:28:31
Message: <3bdd678f@news.povray.org>
Please leave it as 'd:\' and tell me if the next beta install behaves.
thanks,
-- Chris
Date: 30 Oct 2001 21:56:38
Message: <3bdf6866@news.povray.org>
Beta 7 installed fine.  Thanks!
Michael
news:3bdd678f@news.povray.org...
up
beta.
> thanks,
> -- Chris
