POV-Ray : Newsgroups : povray.beta-test : isosurface - contained_by Server Time
13 Oct 2025 16:21:34 EDT (-0400)
  isosurface - contained_by (Message 1 to 4 of 4)
Subject: isosurface - contained_by
Date: 12 Oct 2001 10:36:09
Message: <3bc6ffd9@news.povray.org>
Hello friends,
I'm not sure wether this has already been adressed but I haven't read it.
The following container won't work in isosurfaces:
contained_by { box { <-1,1,-1>,<1,-1,1> }
But this one works:
contained_by { box { <-1,-1,-1>,<1,1,1> }
I found that MegaPOV do the same, but I don't like it... Boxes can normally
be described in any order I want; upside down or inside out.. This
"restriction" seems illogical and is not found in "clipped_by" so just for
making things more transparant for the users, this could be changed.. in my
humble opinion.
Hugo
Subject: Re: isosurface - contained_by
Date: 12 Oct 2001 11:04:08
Message: <3BC70666.2C7815C8@gmx.de>
Hugo wrote:
> Hello friends,
> But this one works:
> humble opinion.
The reason is that the box in the 'contained_by' statement is not the same
as the povray box shape.  It's just a way to describe the borders of the
isosurface with similar, but not necessarily identical syntax.
NTL, it should be easily possible to fix this particular problem with a
minor change.
Date: 12 Oct 2001 11:26:23
Message: <3bc70b9f@news.povray.org>
In article <3bc6ffd9@news.povray.org> , "Hugo" <hua### [at] post3teledk> wrote:
> But this one works:
> humble opinion.
Hi Hugo,
This should have been fixed a long time ago.  As it turns out there is a bug
so it will only correct the X and Z axis, but miss the Y axis.  This will be
corrected in the next beta.
Thank you for finding this bug!
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 12 Oct 2001 13:54:02
Message: <3bc72e3a@news.povray.org>
Although the 'box' keyword here is good and descriptive, it can be extremely
confusing, however. It easily leads the user to think that it's a regular
box *object*, which you can, for example, transform at will (and then the
user sends a "bug" report of this inexistent "bug").
  It's a pitty that it's too late to change this.
