POV-Ray : Newsgroups : povray.beta-test : while bug ? Server Time
1 Aug 2026 01:03:17 EDT (-0400)
  while bug ? (Message 1 to 10 of 27)
Subject: while bug ?
Date: 10 Oct 2001 04:12:39
Message: <3bc402f7$1@news.povray.org>
#local i=0;
#while (i<1)
  #debug concat(str(i,0,2),"\n")
  #local i=i+0.1;
gives
0.00
0.10
0.20
0.30
0.40
0.50
0.60
0.70
0.80
0.90
1.00
is the1.00 normal ???
if we change i=i+0.1 into i=i+0.2 it stops at 0.8
povray3.5b6 win2000 Athlon 900MHz 256MB
M
Subject: Re: while bug ?
Date: 10 Oct 2001 05:18:40
Message: <Xns9136730FC78FDseed7@povray.org>
Same happens in 3.1g
Ingo
Date: 10 Oct 2001 08:00:15
Message: <slrn9s8e2f.9hj.ron.parker@fwi.com>
It's roundoff error.  I is probably .9999999 or so for the last iteration,
but it gets rounded for output.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 10 Oct 2001 08:30:07
Message: <3bc43f4f@news.povray.org>
isn t it strange to get a roundoff error for only 10 additions  ? i thought
pov was more precise :(
M
Date: 10 Oct 2001 08:39:10
Message: <3BC4411A.7060206@videotron.ca>
> M
You can get roundoff error with only one addition.  It comes from the
fact that floating point numbers can not always be converted between
base2 and base10 without roundoff.
To see what happens, you have to modify your code to show all the
decimal places, like this:
#local i=0;
#while (i<1)
   #debug concat(str(i,0,17),"\n")
   #local i=i+0.1;
Which (on my machine) produces:
0.00000000000000000
0.10000000000000001
0.20000000000000001
0.30000000000000004
0.40000000000000002
0.50000000000000000
0.59999999999999998
0.69999999999999996
0.79999999999999993
0.89999999999999991
0.99999999999999989
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 10 Oct 2001 08:46:21
Message: <3bc4431d$1@news.povray.org>
ok, thank you, it's clear.. we can't trust computers for maths :)
i'll change the test in the loop to avoid this
M
Date: 10 Oct 2001 08:54:04
Message: <slrn9s8h7d.9kj.ron.parker@fwi.com>
The problem is that .1 in decimal is a repeating fraction in binary, so it
can never be represented precisely,  just as 1/3 is a repeating fraction in
decimal (but terminates in base 3.)
Date: 10 Oct 2001 08:59:42
Message: <3bc4463e$1@news.povray.org>
> #local i=0;
> #while (i<1)
>   #local i=i+0.1;
> #end
Try
#local i = 0;
#while (i < 10)
  #debug concat(str(i/10, 0, 2), "\n")
  #local i = i + 1;
Since there is no round off error with adding integers.
Date: 10 Oct 2001 09:03:49
Message: <3BC446E1.3090107@videotron.ca>
Yes we can.  As long as we remembers that computers do not have the same
number of fingers to count on.
Date: 10 Oct 2001 09:55:02
Message: <3bc45335@news.povray.org>
Mael <mae### [at] hotmailcom> wrote:
: isn t it strange to get a roundoff error for only 10 additions  ? i thought
: pov was more precise :(
  0.1 can't be represented accurately with binary floating point format.
  The reason is the same as why 1/3 can't be represented accurately with
decimal format.
