POV-Ray : Newsgroups : povray.beta-test : Run tries to force save on other files (Windows) Server Time
26 Jul 2026 06:30:39 EDT (-0400)
  Run tries to force save on other files (Windows) (Message 1 to 3 of 3)
Subject: Run tries to force save on other files (Windows)
Date: 3 Oct 2001 11:21:48
Message: <3bbb2d0c$1@news.povray.org>
Win2000 beta4
Rendering a file will cause all open unsaved files to be saved. If you have a
file that has never been saved, this will cause the save-as dialogue box to
pop-up.
Dunno if this is a feature or a bug. I thought it might be related to the
auto-load option, but it doesn't seem affected by that.
#macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
}light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
Subject: Re: Run tries to force save on other files (Windows)
Date: 3 Oct 2001 14:18:27
Message: <3bbb5673@news.povray.org>
-Hail
  This is a feature, not a bug. It has been like this since old versions
(since povray for windows?). The thing that is annoying is that you have to
manually save the image in order to see any changes made when rendering part
of an image with the mouse selection (that is if you dont set the command
line to do so). If this could be fixed it would make life easyer.
Date: 3 Oct 2001 15:26:39
Message: <3bbb666f$1@news.povray.org>
It normally asks me whether to save the files, but if you check "Don't ask
again" then it won't.
