POV-Ray : Newsgroups : povray.beta-test : Known Bugs Oct 01 Server Time
19 May 2026 02:25:20 EDT (-0400)
  Known Bugs Oct 01 (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Known Bugs Oct 01
Date: 2 Oct 2001 13:53:45
Message: <3bb9ff29@news.povray.org>
What about the "sphere_sweep and radiosity" bug? I hope I don't look like a
monomaniac, but IIRC C. Hormann could replicate that as well... needs this
more confirmation?
Jonathan
"Rune" <run### [at] mobilixnetdk> ha scritto nel messaggio
news:3bb8e6a2@news.povray.org...
> Here are the known and confirmed bugs as per today. Corrections to the
list
> are still very welcome.
> Blob problem
> http://news.povray.org/3b99052c@news.povray.org
> Blob : Toward a solution
> http://news.povray.org/3B991C90.D715B7A3@free.fr
> Superellipsoid epsilon to big ?
> http://news.povray.org/3b992a81@news.povray.org
> Additional (?) blob bug
> http://news.povray.org/Xns9115B92CF7D8ACQ@204.213.191.226
> hf_gray_16 + png creates wrong output image
> http://news.povray.org/3BA3BAE6.4671C0BB@free.fr
> Blob rendering error
> http://news.povray.org/Xns91203DC7F3CCQ@204.213.191.226
> Small window title bug
> (Title switches back to "POV-Ray for Windows" after minimize or restore. )
> http://news.povray.org/3ba92966$1@news.povray.org
> 16-bit PGM pigment and height field problems
> http://news.povray.org/3ba99adb@news.povray.org
> Blend map crash
> http://news.povray.org/3ba9f8e9$1@news.povray.org
> Radiosity with recursion > 1
> (With recursion_limit > 1 clear axis aligned bands appear on the
surfaces.)
> http://news.povray.org/3BAB71AF.B0F503CA@reading.ac.uk
> Rendering animation (MS Windows)
> (Message that indicates the frame to be render is displayed AFTER the
> rendering.)
> http://news.povray.org/3BAC1D0C.74A4A503@free.fr
> Stop during mosaic: crash
> http://news.povray.org/Xns9126925CDC108seed7@povray.org
> sin(X)^sin(X) -> crash!
> http://news.povray.org/3baf7992@news.povray.org
> Bug with parse_string
> http://news.povray.org/9pk0rto8s07dnm320f5m503aqu43ak6g3p@4ax.com
> Spline bug
> (The spline path is all wrong when certain time values are used.)
> http://news.povray.org/3bb41dc8@news.povray.org
> Radiosity crash when user stops render during pretrace.
> http://news.povray.org/3bb4605d$1@news.povray.org
> Highlight bug
> http://news.povray.org/3bb4cf08@news.povray.org
> Macro bug
> (POV can dereference a deallocated pointer if you return a local from a
> macro.)
> http://news.povray.org/3BB4ED11.8EC69CEC@hotmail.com
> Crash after constant function
> http://news.povray.org/kc3hqtkgj93f82rpkj6puvlj8f5cs7nk0q@4ax.com
> Bug with intersection stack (with crash)
> http://news.povray.org/5f13rtc0v0rso4fk7lut5e0980qa9g756b@4ax.com
> Crash with long strings
> (Ignore documentation bug report.)
> 3b54rt8puoibdtdsquqgv1fuo0m9mn6k30@4ax.com
> Rune
Date: 2 Oct 2001 17:26:23
Message: <3BBA31C3.ED219A49@gmx.de>
> more confirmation?
I have mentioned this several times during pre-beta with sample code and
renders so the POV-Team is aware of it.
Should certainly be part of the bug list IMO.
Date: 2 Oct 2001 17:33:20
Message: <3bba32a0$1@news.povray.org>
But it seems like Nathan Kopp cannot replicate it, which is a problem since
it's him who should fix it.
Jonathan
"Christoph Hormann" <chr### [at] gmxde> ha scritto nel messaggio
news:3BBA31C3.ED219A49@gmx.de...
like a
this
> > more confirmation?
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 2 Oct 2001 17:50:59
Message: <3BBA3787.1220A0DA@gmx.de>
Ok, i will post scene and renders again so everyone can try to replicate
it.
Date: 3 Oct 2001 08:30:37
Message: <3bbb04ed@news.povray.org>
Thanks, I have included this bug report on the list.
Rune
Date: 3 Oct 2001 22:22:18
Message: <3BBBC7D9.836D4AC7@iki.fi>
"Redbeard (MDJohnson)" wrote:
> no one seems to have even looked at, or at least replied to.
> http://news.povray.org/3bb2bcc4@news.povray.org
At least I could reproduce it. Beta4, W2k sp2, 2*Celeron 400 on Abit
BP6, 512Mb memory.
          /"\                           |    iki.
          \ /     ASCII Ribbon Campaign |    fi/
           X      Against HTML Mail     |    zds
Date: 7 Oct 2001 17:01:58
Message: <3bc0c2c6@news.povray.org>
"JRG" <jrg### [at] hotmailcom> wrote...
since
Breakthrough!!!!  I figured out why I couldn't replicate your problem.  I
also figured out why adding an "invisible" object made the problem go away.
I have the following lines in my POVRAY.INI file:
Bounding=on
Bounding_Threshold=1
If I comment out the second line, I am able to replicate the problem.  These
settings determine if POV-Ray uses bounding slabs, which in turn affects the
use of light buffers and use of the vista buffer.
I still don't know the exact cause of the problem, but I'm getting much
closer now!
For now, the workaround is to add those two lines to your povray.ini file.
-Nathan
Date: 7 Oct 2001 17:29:50
Message: <3BC0CA36.7F220857@gmx.de>
> Bounding=on
Hmm, interesting.  Isn't it normally that bounding causes problems and not
that they are solved by it?
Date: 7 Oct 2001 18:45:54
Message: <3bc0db22@news.povray.org>
I wonder what is the purpose for the bounding threshold? Why it couldn't
be just 1 and that's it? Is there any case where this would make rendering
considerably slower (and I'm not talking about 3 seconds vs. 1 second, but
for example 30 minutes vs. 10 minutes)?
Date: 11 Oct 2001 18:41:56
Message: <3bc62034@news.povray.org>
That's good to hear.
The only problem is that the scene which showed me the bug the first time
contains some thousands objects, so I think bounding was used by default.
Jonathan.
"Nathan Kopp" <nat### [at] koppcom> ha scritto nel messaggio
news:3bc0c2c6@news.povray.org...
> since
away.
> Bounding=on
These
the
> closer now!
> -Nathan
