POV-Ray : Newsgroups : povray.beta-test : Fatal error. Server Time
19 Feb 2026 02:22:20 EST (-0500)
   Fatal error. (Message 1 to 6 of 6)
Subject: Fatal error.
Date: 29 Sep 2001 10:23:02
Message: <3bb5d946$1@news.povray.org>
Hello ,there.
I were experimenting with photons and dispersion feature  ,and got a crash
when renderind the attached. It is consistent. I get the error ,when
"sorting photons".
Download 'prism.pov.txt' (5 KB)
Subject: Re: Fatal error.
Date: 29 Sep 2001 10:46:11
Message: <3bb5deb3@news.povray.org>
Crashes here, too. But if you set spacing to 0.0115 (or higher - 0.011
crashes as well) works. /wild guess/ Perhaps some overflow at 128k photons
(this number seems to be reached at 0.011)? /wild guess/
Marc-Hendrik
PII 450, Win 98, 128 MB, Pov 3.5 beta 4
YE.S schrieb in Nachricht <3bb5d946$1@news.povray.org>...
>  Hello ,there.
>"sorting photons".
Date: 29 Sep 2001 10:52:37
Message: <3bb5e035@news.povray.org>
Pov crashes too if you replace "spacing 0.01" by "count 130000".
Oh and Window reports a "Stapelfehler" (=stack error/overflow???) at
015f:00477df0.
Marc-Hendrik
Date: 29 Sep 2001 16:42:40
Message: <3bb63240@news.povray.org>
Please don't post povray files in binary-encoded format, but just as raw
text.
  (Yes, I know that some braindead news readers do this without even warning
the user or showing that it is doing that. I think that opening the povray
file in an editor (eg. POV-Ray itself) and then copy-pasteing into the
newsreader editor works as it should.)
Date: 29 Sep 2001 16:52:56
Message: <3bb634a8$1@news.povray.org>
news:3bb63240@news.povray.org...
> text.
warning
 I believe ,the .pov files are in regular ascii text format ,so what was rhe
problem ?
Date: 29 Sep 2001 17:54:01
Message: <nigcrtkn9gvld2e8m7ldlb4ei627vn912j@4ax.com>
>problem ?
There is a difference between pasting a raw ascii text file in a
message and attaching it as an uuencoded file. In the second case, it
has to be decoded before it is read plus it can not be viewed directly
with the message describing it.
Peter Popov ICQ : 15002700
