POV-Ray : Newsgroups : povray.beta-test : Known Bugs Sep 28 Server Time
28 Apr 2026 17:59:08 EDT (-0400)
  Known Bugs Sep 28 (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: nevermind
Date: 28 Sep 2001 23:02:50
Message: <3bb539da@news.povray.org>
Just found a message by Bonsai here from the 24th saying the same thing I
just did about File Init Error.  Ron suggests it would be fixed in Beta 5.
Bob H.
Date: 28 Sep 2001 23:30:28
Message: <slrn9rag2o.6ml.ron.parker@fwi.com>
Or some future beta.  One never knows; I might check it in just after Chris
starts building the beta.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Subject: Re: Known Bugs Sep 28
Date: 30 Sep 2001 17:27:02
Message: <3bb78e26@news.povray.org>
You forgot to mention the *sphere_sweep with radiosity bug*
Jonathan
"Rune" <run### [at] mobilixnetdk> ha scritto nel messaggio
news:3bb4956d@news.povray.org...
> Here are the known and confirmed bugs as per today. Corrections to the
list
> are still very welcome.
> 18077  Blob problem
> http://news.povray.org/povray.beta-test/18087/
> 18089  Blob : Toward a solution
> http://news.povray.org/povray.beta-test/18089/
> 18094  Superellipsoid epsilon to big ?
> http://news.povray.org/povray.beta-test/18094/
> 18105  Additional (?) blob bug
> http://news.povray.org/povray.beta-test/18105/
> 18391  hf_gray_16 + png creates wrong output image
> http://news.povray.org/povray.beta-test/18391/
> 18456  Blob rendering error
> http://news.povray.org/povray.beta-test/18456/
> 18522  Small window title bug
> (Title switches back to "POV-Ray for Windows" after minimize or restore. )
> http://news.povray.org/povray.beta-test/18522/
> 18529  16-bit PGM pigment and height field problems
> http://news.povray.org/povray.beta-test/18529/
> 18535  Blend map crash
> http://news.povray.org/povray.beta-test/18535/
> 18565  Radiosity with recursion > 1
> (With recursion_limit > 1 clear axis aligned bands appear on the
surfaces.)
> http://news.povray.org/povray.beta-test/18565/
> 18577  Rendering animation (MS Windows)
> (Message that indicates the frame to be render is displayed AFTER the
> rendering.)
> http://news.povray.org/povray.beta-test/18577/
> 18638  Stop during mosaic: crash
> http://news.povray.org/povray.beta-test/18638/
> 18650  sin(X)^sin(X) -> crash!
> http://news.povray.org/povray.beta-test/18650/
> 18672  Bug with parse_string
> http://news.povray.org/povray.beta-test/18672/
> 18740  Spline bug
> (The spline path is all wrong when certain time values are used.)
> http://news.povray.org/povray.beta-test/18740/
> 18746  Radiosity crash when user stops render during pretrace.
> http://news.povray.org/povray.beta-test/18746/
> Rune
> 3D images and anims, include files, tutorials and more:
> Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
> POV-Ray Users:   http://rsj.mobilixnet.dk/povrayusers/
> POV-Ray Webring: http://webring.povray.co.uk
Date: 1 Oct 2001 11:23:02
Message: <a1vgrtgkmem30dmqvmd265tulhpivjsb9l@4ax.com>
On Fri, 28 Sep 2001 17:15:53 +0200, "Rune"
<run### [at] mobilixnetdk> wrote:
> Here are the known and confirmed bugs as per today. Corrections to the list
Perhaps there is a reason but you attached only one my post.
Here are other not finished with explanation or "will be fixed"
  Crash after constant function
  http://news.povray.org/povray.beta-test/18496/
  Bug with intersection stack (I gave solution)
  http://news.povray.org/povray.beta-test/18696/
  #if inside #if (but Nathan said - no solution anywhere :-( )
  http://news.povray.org/povray.beta-test/18701/
  Another string bug (or even two)
  http://news.povray.org/povray.beta-test/18706/
  Old accuracy bug - perhaps with no chance to fix
  http://news.povray.org/povray.beta-test/18702/
There is also something new from me
  Select within select
  http://news.povray.org/povray.beta-test/18823/
I answered for your request for help
  http://news.povray.org/povray.beta-test/18618/
Have you readed this? Was this helpful ? Should I continue ?
ABX
Date: 1 Oct 2001 14:27:09
Message: <3bb8b57d@news.povray.org>
> one my post. Here are other not finished with
Note:
Only confirmed bugs can get on the list.
You couldn't know this, but for the future, please specify messages this
way:
http://news.povray.org/Xns9115B92CF7D8ACQ@204.213.191.226
(The part after http://news.povray.org/ is the message ID.)
I'll add this.
I'll add it.
That's not a bug but a limitation.
I'll add "Crash with long strings, ignore documentation bug report"
This bug doesn't seem to have been confirmed.
This hasn't been confirmed properly.
Yes. Yes. Yes. (Sorry I didn't answer before to that.)
Rune
Date: 22 Oct 2001 05:11:25
Message: <ahn7ttc31av05805lom27csqk778mpdvvl@4ax.com>
On Mon, 1 Oct 2001 20:28:47 +0200, "Rune"
ok.
> way:
where on the www interface I can find it that way ?
> I'll add this.
is seems it's gone for beta 6
> I'll add it.
it still present for beta 6
than I must wait for sources :-(
can anybody confirm this ?
I can confirm that it still present for beta 6
yes, wrong noise generator
ok, I see it is still not finished for beta 6 therefore I'll start
with it.
ABX
Date: 22 Oct 2001 06:47:01
Message: <3bd3f925@news.povray.org>
Just _follow_ the link, at is all you need to do to find it.
    Thorsten
e-mail: tho### [at] trfde
Date: 22 Oct 2001 08:12:42
Message: <q338tt4tlomhlieng38togpei5t3i8phf4@4ax.com>
On Mon, 22 Oct 2001 12:46:59 +0200, "Thorsten Froehlich"
perhaps there is some limitation in my English but I not asked how use
links but how generate link with message ID having opened message via
www interface
ABX
Date: 22 Oct 2001 08:44:14
Message: <3bd4149e@news.povray.org>
> www interface
No, this is a mistake on my part.  I misunderstood the question.
The short answer is: You can't.
The long answer is: You can build it on your own, but you need a newsreader
that can show you the message header.  Then just take the message ID header
field and combine it with the link to the main newsgroup web interface page.
While the resulting link is not compatible with old browsers (because the
URL isn't encoded properly), it will work with all more recent browsers.
Alternatively you can use Netscape to get a link in the same format with a
properly encoded URL.  You just change the news:// Netscape puts in front to
a http:// and you are all set.  The web interface does not care if the URL
is encoded properly or not.
    Thorsten
Date: 22 Oct 2001 14:07:36
Message: <3bd46068@news.povray.org>
> therefore I'll start with it.
Thank you! It's very appreciated.
Rune
