POV-Ray : Newsgroups : povray.beta-test : Known Bugs Sep 28 Server Time
28 Apr 2026 16:08:32 EDT (-0400)
  Known Bugs Sep 28 (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Known Bugs Sep 28
Date: 22 Oct 2001 08:44:14
Message: <3bd4149e@news.povray.org>
Skiba <abx### [at] babilonorg>  wrote:
>> Just _follow_ the link, at is all you need to do to find it.
> perhaps there is some limitation in my English but I not asked how use
> links but how generate link with message ID having opened message via
> www interface
No, this is a mistake on my part.  I misunderstood the question.
The short answer is: You can't.
The long answer is: You can build it on your own, but you need a newsreader
that can show you the message header.  Then just take the message ID header
field and combine it with the link to the main newsgroup web interface page.
While the resulting link is not compatible with old browsers (because the
URL isn't encoded properly), it will work with all more recent browsers.
Alternatively you can use Netscape to get a link in the same format with a
properly encoded URL.  You just change the news:// Netscape puts in front to
a http:// and you are all set.  The web interface does not care if the URL
is encoded properly or not.
    Thorsten
e-mail: tho### [at] trfde
Date: 22 Oct 2001 14:07:36
Message: <3bd46068@news.povray.org>
> ok, I see it is still not finished for beta 6
> therefore I'll start with it.
Thank you! It's very appreciated.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Date: 29 Oct 2001 06:01:16
Message: <madqttov353hsu8gaef92809kscol9pre3@4ax.com>
this macro is not on the list but I think it could be usefull
(and that's why I talked so much about declaring arrays
and pointing to elements with loops - this macro could
be veeery short with it)
// Array - an array to be resized
// Dimension - number of dimension to be resized
// NewSize - new number of entries for Dimension of Array
#macro Resize_Multi_Array(Array, Dimension, NewSize)
    #if((Dimension>0)&(dimensions(Array)>=Dimension)&(int(Dimension)=Dimension))
        #if(dimensions(Array)!=1)
            #switch(dimensions(Array))
                #case(2)
                    #local NewArray=array
                        [(Dimension!=1?dimension_size(Array,1):NewSize)]
                        [(Dimension!=2?dimension_size(Array,2):NewSize)]
                    #local Max1 =
min(dimension_size(NewArray,1),dimension_size(Array,1));
                #break
                #case(3)
                        [(Dimension!=3?dimension_size(Array,3):NewSize)]
                #break
                #case(4)
                        [(Dimension!=4?dimension_size(Array,4):NewSize)]
                #break
                #case(5)
                        [(Dimension!=5?dimension_size(Array,5):NewSize)]
                #break
                #else
                    #error "Wrong Dimension argument in Resize_Multi_Array macro"
            #local Max=array[dimensions(Array)]
            #local C=0;
            #while (C<dimensions(Array))
              #local
Max[C]=min(dimension_size(NewArray,C+1),dimension_size(Array,C+1));
              #local C=C+1;
            #local C=Max
                #case(2)
                    #local C[0]=0;
                    #while (C[0]<Max[0])
                        #local C[1]=0;
                        #while(C[1]<Max[1])
                            #ifdef(Array[C[0]][C[1]])
                                #local NewArray[C[0]][C[1]] = Array[C[0]][C[1]];
                            #local C[1] = C[1] + 1;
                        #local C[0] = C[0] + 1;
                #break
                #case(3)
                    #local C[0]=0;
                        #local C[1]=0;
                        #while(C[1]<Max[1])
                            #local C[2]=0;
                            #while(C[2]<Max[2])
                                #ifdef(Array[C[0]][C[1]][C[2]])
                                    #local NewArray[C[0]][C[1]][C[2]] =
Array[C[0]][C[1]][C[2]];
                                #local C[2] = C[2] + 1;
                #break
                #case(4)
                    #local C[0]=0;
                        #local C[1]=0;
                        #while(C[1]<Max[1])
                            #local C[2]=0;
                            #while(C[2]<Max[2])
                                #local C[3]=0;
                                #while(C[3]<Max[3])
                                    #ifdef(Array[C[0]][C[1]][C[2]][C[3]])
                                        #local NewArray[C[0]][C[1]][C[2]][C[3]] =
Array[C[0]][C[1]][C[2]][C[3]];
                                    #local C[3] = C[3] + 1;
                #break
                #case(5)
                    #local C[0]=0;
                        #local C[1]=0;
                        #while(C[1]<Max[1])
                            #local C[2]=0;
                            #while(C[2]<Max[2])
                                #local C[3]=0;
                                #while(C[3]<Max[3])
                                    #local C[4]=0;
                                    #while(C[4]<Max[4])
                                        #ifdef(Array[C[0]][C[1]][C[2]][C[3]][C[4]])
                                            #local
NewArray[C[0]][C[1]][C[2]][C[3]][C[4]] = Array[C[0]][C[1]][C[2]][C[3]][C[4]];
                                        #local C[4] = C[4] + 1;
                #break
                #else
            #declare Array = NewArray
        #else
            Resize_Array(Array,NewSize)
    #else
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 29 Oct 2001 12:25:15
Message: <3bdd90fb@news.povray.org>
Hmm, I don't know, so I'd like to hear the opinions of others. Is this macro
useful enough for inclusion?
Rune
Date: 29 Oct 2001 13:10:45
Message: <3bdd9ba5$1@news.povray.org>
Why don't you allow the array to be one-dimensional? I know that there are
other macros for one-dimensional arrays, but it's trivial to add and it
would make this macro truly general-purpose.
Date: 30 Oct 2001 02:55:36
Message: <3BDE5CB2.5000400@yahoo.fr>
Yes imho
Philippe
Date: 31 Oct 2001 02:49:56
Message: <02bvttc9u5b4slf1arg3c6kbdtga15vvpn@4ax.com>
On Mon, 29 Oct 2001 18:19:33 +0100, "Rune"
I've designed this macro becouse I planned to write Append_To_Array
and Append_Array_To_Array macros working multidimensional.
ABX
Date: 31 Oct 2001 02:51:07
Message: <v8bvttsq74vv2n9rh68sdfj2nh1d0h48t7@4ax.com>
On Mon, 29 Oct 2001 13:12:59 -0500, "Anders K." <and### [at] f2scom>
perhaps you missed this but I don't allow, I just call ready macro to
not duplicate code within one inc file.
ABX
Date: 31 Oct 2001 10:23:07
Message: <3be0175b$1@news.povray.org>
You're right, I did miss this.
Date: 9 Nov 2001 10:05:35
Message: <s3snut4mqu9u2pp1ndms5i0dstp6gqulfb@4ax.com>
I still wait for the answer becouse I don't get strategy for rest of macros.
ABX
