POV-Ray : Newsgroups : povray.beta-test : Shellout command line contains trailing \r\n Server Time
1 Aug 2026 03:56:03 EDT (-0400)
  Shellout command line contains trailing \r\n (Message 1 to 2 of 2)
Subject: Shellout command line contains trailing \r\n
Date: 24 Sep 2001 09:10:16
Message: <3baf30b8@news.povray.org>
When Pov 3.5 Beta4/Windows launches another process from Post_Scene_Command,
it appends \r\n to the command line. This causes problems, at least when
invoked program is written in MSVC. MSVC startup code parses command line
and puts the parameters into argc/argv, however, it doesn't strip trailing
\r\n and last argument will contain these additional characters. If it's a
filename, CreateFile or fopen will fail.
This does not depend on the number of empty lines following
Post_Scene_Command.
This doesn't happen at all on PovRay 3.1g and earlier releases.
Tomasz Sowinski
Subject: Re: Shellout command line contains trailing \r\n
Date: 24 Sep 2001 23:06:52
Message: <slrn9qvt6g.1o3.ron.parker@fwi.com>
I believe this should be fixed in the next beta, but I haven't tested it
extensively.  Further tests upon receipt of beta 5 are encouraged.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
