POV-Ray : Newsgroups : povray.beta-test : png gamma error Server Time
19 May 2026 05:44:36 EDT (-0400)
  png gamma error (Message 21 to 29 of 29)
Subject: Re: png gamma error
Date: 25 Sep 2001 10:55:05
Message: <3bb09ac9@news.povray.org>
In article <3bb09022@news.povray.org> , "Bob H." <omn### [at] msncom> wrote:
> Does this mean only a LCD is liable to be okay for setting both display and
> assumed gamma to 1.0?  Or is that okay for a CRT too?  I take it the answer
> is no.
You should be able to measure your display and have software adjust the
color representation accordingly.  Of course, with a CRT this is much easier
because its colors usually don't change much when viewed from a different
angle.  So, if you are up for a 'realistic' color representation, calibrated
output on a CRT is preferable over any LCD.  Of course, in a few years this
might change once better LCDs or other technologies are available.
    Thorsten
e-mail: tho### [at] trfde
Date: 25 Sep 2001 11:12:50
Message: <3BB09F2D.EAB9E5EB@engineer.com>
> is no.
When assumed_gamma=Display_Gamma the samples written to the image file
are linear. Easier way to make this happen is not to use assumed_gamma
at all.
It all depends on whether you want gamma correction or not. Because
povray can't do correction for LCD displays you have to find another
way to do it and have povray output linear samples. Most of the time
it's sensible to enable gamma correction when working with CRT.
You are of course free to use any means to get the image look good on
LCD but...
Then there is the problem of publishing images designed on LCD. Because
99% of images are not viewed on LCDs the LCD correction has to be removed
and (preferably) gamma 2.2 applied before publishing. When using 8 bit
samples this means the image will be in pretty bad shape after all these
conversions.
_____________
Kari Kivisalo
Date: 25 Sep 2001 12:54:44
Message: <3bb0b6d4@news.povray.org>
From all this discussions it's starting to seem to me that the best way
to go is just that POV-Ray would not write any gamma correction value to
the PNG. This way it works exactly like when writing to any other image
format.
  As this only requires commenting out 2 lines of the source code, it should
be easy to implement. Of course it can be discussed (for an eternity) whether
this really is the correct way of doing it.
  If the final version of 3.5 will behave like the current beta, I'll certainly
comment that part myself by hand when compiling the unix version. Of course
the Windows version will still have the problem as I don't have any compiler
for that...
Date: 25 Sep 2001 14:13:35
Message: <3bb0c94f$1@news.povray.org>
I insist on the png bug in beta 3 (and 4).
The png output is different from the bmp output, when I use Polyview as a
viewer program.
Beta 1, beta 2 and any other pov-ray version behaved okay and now something
has changed lately.
IIRC there was something "hacked".
Or am I too stupid to understand the whole discussion?
Norbert
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:3bb0b6d4@news.povray.org...
> format.
Date: 25 Sep 2001 14:30:57
Message: <3bb0cd61@news.povray.org>
I can confirm the bug here (beta 4, WinNT 4). It depends on the viewer
however : I have no problem with Micrografx Publisher but Microsoft Image
Composer and Netscape 6.1 show a clear difference.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
3badbff6$1@news.povray.org...
> Hi all!
> System: POV-Ray for Windows v3.5b3, Win98SE, AMD Athlon 1.4 GHz,
>             1024 megs SDRam
> PNG output (by +fn) in beta 3 makes image output way too bright. It can
only
> be seen with an extern viewer, not while rendering. It seems output has a
> gamma of 1.0 while it should be 2.2.
> Beta 2 behavior was correct.
> Norbert
Date: 25 Sep 2001 15:28:22
Message: <3bb0dad6@news.povray.org>
Norbert Kern <nor### [at] t-onlinede> wrote:
: The png output is different from the bmp output
  No, it isn't. It's just that POV-Ray outputs a gamma correction value to
the PNG which is not correct and the viewer program uses this gamma correction
value.
Date: 25 Sep 2001 15:29:19
Message: <3bb0db0f@news.povray.org>
Gilles Tran <tra### [at] inapginrafr> wrote:
: It depends on the viewer however
  This is because all programs do not support/use the gamma correction value
of the PNG file.
Date: 25 Sep 2001 15:41:18
Message: <3bb0ddde@news.povray.org>
"Kari Kivisalo" <ray### [at] engineercom> wrote in message
news:3BB09F2D.EAB9E5EB@engineer.com...
and
answer
> > is no.
> at all.
Okay.  I stumbled across this web page that might be interesting to some:
http://positron.cs.berkeley.edu/gwlarson/vrml  (this is the directory
instead, I had some trouble using links there)
> LCD but...
> conversions.
Thanks for the reply as well Thorsten.  However the notebook LCD I have here
is probably not worth the effort to try and correct.  I sent the first one
back because of how the screen shifts in brightness from top to bottom.  I
thought getting a TFT Active Matrix kind would be better than it is for this
DELL.  My first experience with them and not a great one.  A trade off from
somewhat fuzzy, yet evenly lit, CRT to polarized-like, yet clear as it gets,
LCD.
Bob H.
Date: 25 Sep 2001 15:46:38
Message: <3bb0df1e@news.povray.org>
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:3bb0cd61@news.povray.org...
Might want to have a look at the web pages I came upon authored by someone
from Silicon Graphics and IBM concerning linear gamma (?) for consistency in
VRML conversion to other renderers.  At least I think that was the idea
expressed.
Bob H.
