POV-Ray : Newsgroups : povray.beta-test : png gamma error Server Time
19 May 2026 04:44:04 EDT (-0400)
  png gamma error (Message 11 to 20 of 29)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: png gamma error
Date: 24 Sep 2001 13:53:53
Message: <3baf7331$1@news.povray.org>
I followed the diskussion and you are surely right, in an academic sense.
I reported the bug, because the BMP and the PNG output were different on
Polyview.
Polyview had shown no problem with earlier beta and other pov-ray versions.
My assumed_gamma value is 1 since some months, so there should be no
difference anyway.
I don`t know, where I can see my Display_Gamma, but it should be normal.
Norbert
> What are your assumed_gamma and Display_Gamma settings?
Date: 24 Sep 2001 14:24:49
Message: <3baf7a70@news.povray.org>
Kari Kivisalo <ray### [at] engineercom> wrote:
: I wonder how many applications actually use the png gamma information?
  At least xv, Image Magick and Netscape 6.x in unix. All of them use the
gamma correction value and show the same result.
Date: 24 Sep 2001 14:57:27
Message: <3baf8217@news.povray.org>
"Norbert Kern" <nor### [at] t-onlinede> wrote in message
news:3baf7331$1@news.povray.org...
> Polyview.
versions.
> difference anyway.
POV directory\renderer\povray.ini holds the Display_Gamma= if you have one.
Bob H.
Date: 24 Sep 2001 16:23:08
Message: <Xns9126E3B74B171seed7@povray.org>
in news:3baf6e49$1@news.povray.org Bob H. wrote:
> For PC systems, the most common display gamma is 2.2, while for
> scenes created on Macintosh systems should use a scene gamma of
> 1.8. Another gamma value that sometimes occurs in scenes is 1.0.
 Guessing (as I used a pre 3.1 versions only for a week or two): going
from version 2.2/3.0/3.1 a few things changed. In older versions you
had to set the resulting gamma in the scene file. When a scene was
designed on a Mac and renderd on a PC there had changes to be made to
the scene file.
 In the current situation this is not needed anymore as display_gamma
is set in the INI file, or defaults to the right value (at least
for PC). assumed_gamma 1 just tells the system to use that
display_gamma. final gamma = display_gamma/assumed_gamma, so
assumed_gamma can be used to make small changes to the illumination of
the scene, but in general it would be better to do it with the
lightning sceme to prevent cross platform problems.
 As to the value to be written to the PNG file, shouldn't it be
1/final_gamma instead of 1/display_gamma? Or is that one correction too
much?
Ingo
Date: 25 Sep 2001 04:14:53
Message: <3bb03cfd@news.povray.org>
"ingo" <ing### [at] homenl> wrote in message
news:Xns### [at] povrayorg...
> the scene file.
> much?
Don't know, but looking at the last line of the last paragraph of section
5.2.2.2 in the doc I see it says newer hardware could use Display_Gamma 1.0.
Having tried that just now since I have the ATI mobility 128, which must
certainly have gamma correction of some sort, and putting assumed_gamma 1.0
as recommended I get a perfectly good rendering.  So it was the visually
adjusted display gamma I had always set before which messed that idea up.  I
kept thinking display gamma had to be set manually by using the graphic
supplied in the doc.
Anyway, I'll be checking into this once again to find how the images end up.
Bob H.
Date: 25 Sep 2001 04:34:22
Message: <3BB041E4.76733B14@sycomore.fr>
Most card drivers allow you to change the gamma to any
value you want. So you can work at gamma 1.0. OTOH, lots
of people will then complain about your images. IIRC,
Fabien Mosen told me he worked at a gamma around 1.7.
But what was your Display_Gamma?
> I
Definitely yes.
Adrien Beau - adr### [at] freefr - http://adrien.beau.free.fr
 Mes propos n'engagent que moi et en aucun cas mes employeurs
Subject: Re: png gamma error [bug]
Date: 25 Sep 2001 04:38:40
Message: <3BB042E7.2FDE49C1@sycomore.fr>
> Polyview.
That's interessant! I don't think this is a correct behaviour.
Can anybody else test it? I'm at work and I can't.
Have you tried other programs?
E.g. http://www.irfanview.com is not a very big download (~600KB)
Date: 25 Sep 2001 05:05:21
Message: <3bb048d1@news.povray.org>
"Adrien Beau" <adr### [at] sycomorefr> wrote in message
news:3BB041E4.76733B14@sycomore.fr...
section
1.0.
1.0
1.0 also, as was suggested for newer (about post-1995 do you think? :-))
video hardware in the doc.
> Definitely yes.
If I set that to 2.3 though, which is what I get for the LCD screen near as
I can tell, then I must use assumed_gamma 2.3 also or none at all.  Using
1.0 for both settings is the exact same thing.  This is what I wonder about
then, whether it makes any difference once rendering on another machine.
This of course depends on whether or not assumed gamma is applied at all or
not.
Apparently the concept of using 1.0 for both isn't expressed in no uncertain
terms, that's why I always set display gamma to a visual appearance and then
expected assumed gamma would compensate from there.  Sorry about being so
inept about this but it's one of those things that leads me in circles.
I'm posting (yet another) gamma comparative image to p.b.i. in a minute just
to see if anyone has some more ideas on this cross-platform stuff which I
have no idea about.
Bob H.
Date: 25 Sep 2001 07:09:35
Message: <3BB0662D.236C2598@engineer.com>
LCD and gamma don't mix. Gamma correction is for CRT only.
The response curve of non compensated LCD displays is totally
different from CRT response and trying to measure or apply
gamma with that hardware won't do much good.
I know there are TFT displays that emulate sRGB CRT and those
are hard wired to gamma 2.2. They can be used for graphics work
but the LCD displays I have seen have been non compensated
and unsuitable for editing graphics.
So, if the manual that came with the hardware doesn't mention
anything about sRGB, CRT or gamma emulation forget gamma.
Quick search produced this review about LCD projectors. What is
said here applies also to LCD displays. In short, LCD displays
are problematic.
From http://www.zdnet.co.uk/pcmag/labs/2000/04/projectors/21.html
Gamma is a critical parameter for any display product because it
determines how accurately tonal values are reproduced. Although
this might not be so important for high-contrast business
graphics, it's important for the reproduction of natural
images--high-quality images of fine art, for example. Displays
with response curves that follow a power curve
(but with the 'wrong' exponent) can be corrected to the desired
curve. However, some display products exhibit black and white
compression, resulting in an S-shaped curve. Unless this can be
removed by manipulation of the brightness and contrast controls,
images displayed by these products can't be improved purely by
simple gamma correction.
The gamma characteristics for many of these projectors show large
deviations from the ideal, and the controls that relate to gamma
contrast and brightness were difficult to set. In this review, the
Philips Hopper XG10 and, to a lesser extent, the Toshiba TLP651E
both have S-shaped gamma curves.
_____________
Kari Kivisalo
Date: 25 Sep 2001 10:09:38
Message: <3bb09022@news.povray.org>
Oh yeah, sorry about forgetting what you said a few months ago concerning
that.  Thanks.
Does this mean only a LCD is liable to be okay for setting both display and
assumed gamma to 1.0?  Or is that okay for a CRT too?  I take it the answer
is no.
Bob H.
"Kari Kivisalo" <ray### [at] engineercom> wrote in message
news:3BB0662D.236C2598@engineer.com...
> are problematic.
> _____________
> Kari Kivisalo
