POV-Ray : Newsgroups : povray.beta-test : Shell-Out bug Server Time
26 Jul 2026 09:26:58 EDT (-0400)
  Shell-Out bug (Message 1 to 4 of 4)
Subject: Shell-Out bug
Date: 23 Sep 2001 05:16:12
Message: <3bada85c@news.povray.org>
While povray supports shell-outs on the command line, if this option is used
in an ini file povray ignores it.
Subject: Re: Shell-Out bug
Date: 24 Sep 2001 22:28:17
Message: <slrn9qvqu4.f7.ron.parker@fwi.com>
This might be related to the other post in this newsgroup about trailing
CRLF on the shell command.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 25 Sep 2001 02:13:02
Message: <3bb0206e@news.povray.org>
Can't be.  The problem here is in INI files.  Shell-outs seem to work as
they should on a command line, just not in an INI file.
Date: 25 Sep 2001 09:22:05
Message: <slrn9r117v.4ae.ron.parker@fwi.com>
So is the problem with the CRLF on the end of the line.  The CRLF gets
picked up from the INI file and passed on as part of the shellout command.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
