POV-Ray : Newsgroups : povray.beta-test : 16-bit PGM pigment and height field problems Server Time
19 May 2026 04:43:07 EDT (-0400)
  16-bit PGM pigment and height field problems (Message 11 to 15 of 15)
Subject: Re: 16-bit PGM pigment and height field problems
Date: 3 Oct 2001 04:58:21
Message: <3bbad32c@news.povray.org>
Mike Hough <Ama### [at] aolcom> wrote:
: Did you mean to delete this message?  I didn't appreciate it and don't
: understand how you could have fixed a bug if my report was erroneous.  I
: misunderstood what you meant by a 'word' and believe it was an honest
: mistake.
  If you wrote a post that offended him, even if it was unintentional, it's
not him who should apologize to you, but the other way around.
: I'll be sure not to post anymore bugs because it's simply not worth this.
  "I make a mistake and get corrected, so I will never again post any bug
report." Makes sense.
Date: 3 Oct 2001 09:17:39
Message: <slrn9rm3vk.jd3.ron.parker@fwi.com>
On Tue, 2 Oct 2001 22:29:02 -0500, Mike Hough wrote:
>Btw, the offset in the map was an error with the orginal DEM files the USGS
>released.  The non-square data is saved as a part of a square to prevent
>distortion without scaling.
No, the offset in the map is because UTM is not "square" unless you're on
a meridian.  If you account for the projection, that problem goes away.  I
used to write GIS software; I dealt with USGS products all the time.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 3 Oct 2001 17:20:46
Message: <3bbb812e@news.povray.org>
SDTS DEM Positional Error (Source: USGS)
One positioning error is isolated to the spatial domain module of the SDTS
file. This module contains the UTM corner coordinates of the file's bounding
rectangle. Because of coordinate rounding errors, these bounding corner
coordinates may be off as much as one meter in x and/or y from their proper
positions. This rounding error, however, does not affect the positions of
the internal DEM post coordinates. Because the bounding rectangle was
calculated independently from the internal coordinate positions, it is
possible that some internal post coordinates may actually lie as much as one
meter outside the footprint of the bounding rectangle. Programs that do not
attempt to register the DEM tiles using coordinates of the spatial domain
module will not be affected by this coordinate rounding error.
The other positioning error affects the coordinates of the internal DEM
posts for SDTS 10-meter and 30-meter DEMs. This problem results from the use
of an incorrect origin for the SDTS UTM grid calculated for each 7.5-minute
tile. Rather than placing grid posts at 10- or 30-meter increments from a
consistent origin within the respective UTM zone, the 10- or 30-meter
step-over in northing and easting was calculated from the minimum easting
and maximum northing (northwest corner) of the target DEM cell. The error
for each SDTS tile will vary depending on the orientation of the UTM grid to
the 7.5-minute latitude and longitude of the original DEM corners. The x or
y error between any grid post's correct horizontal position and calculated
position will not exceed the spatial resolution of that particular DEM. This
error will be consistent for all elevations within a 7.5-minute tile but may
vary across tiles. When this error varies across tiles, column or row
drop-out may be evident along the common edge of those tiles.
There is no simple offset or translation that can be applied to the existing
SDTS DEMs to correct for these conversion errors. The USGS is presently
considering the proper action to be taken regarding this problem. These
problems have been fixed in the SDTS conversion software, therefore, any
SDTS DEMs created after January 1, 2001 will contain correct positioning.
My understanding is that this was a problem when using SDTS DEM files with
Bryce.  Bryce may very well not account for the projection but I thought
this could be what you were seeing.
Date: 3 Oct 2001 17:30:33
Message: <slrn9rn0rs.k2v.ron.parker@fwi.com>
Nope, those are tiny position errors.  What I was seeing is that the
edges of the tile aren't horizontal and/or vertical, which is a sign that
the program didn't take the projection into account.  Unfortunately (well,
actually quite fortunately, as far as I'm concerned) I don't work for the
GIS company anymore, and it's been long enough that I don't have any of
the necessary resources for converting from UTM to degrees/minutes/seconds
anymore.
In any event, as long as the tiles are small enough you can probably use
an appropriate rotation to make them almost right.  I just thought I'd
point it out in case you were counting on +Y being north or some such thing.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 3 Oct 2001 19:56:54
Message: <3bbba5c6@news.povray.org>
Anyone else got anything personal to say about my character?
