Am getting a weird result with this (can anybody with beta2 confirm?):
isosurface {
function {(x+y)^3}
contained_by {sphere {0, 2}}
pigment {color rgb <.5, .35, .15>}
Atleast I *think* I am (since I'm learning isosurfaces using the docs)
and megapov seems to confirm it. I'm using povray3.5 beta1 on a win98
machine.
Sorry to bring a beta1 problem here but, with my downloading speed
(and with other items in the que), by the time I finish downloading
beta2 , it will be time for beta3:(
Incidentally, a big Thank You to whoever wrote the docs on isosurfaces
(especially): I now see the light (and isosurfaces - even if I need
Megapov really appreciate them:))
Anoop
Wasn't it anoop who wrote:
>Hi,
> isosurface {
> function {(x+y)^3}
>machine.
This particular function needs a largish max_gradient. Try adding
"max_gradient 10". Also, adding "open" to the end of your contained by
may[1] help you see the actual surface, rather than the edge of your
contained_by object.
Here's a complete scene that shows the surface behaving correctly in
3.5b2
camera { location <1, 0, -4> look_at 0}
sky_sphere { pigment {rgb z}}
light_source {<100,100,-200> colour rgb 2}
isosurface {
function {(x+y)^3}
max_gradient 10
contained_by {sphere {0, 2}} open
My Isosurface Tutorial has now been updated to include 3.5 syntax if
that helps <http://www.econym.demon.co.uk/isotut/index.htm>. In
particular the page of that tutorial relevant to this situation is
<http://www.econym.demon.co.uk/isotut/maxgradient.htm>
[1]Depending on which side of the plane you've positioned your camera.
Mike Williams
Gentleman of Leisure
Mike Williams wrote in message ...
>>Hi,
confirm?):
>> isosurface {
>> function {(x+y)^3}
docs)
win98
>>machine.
by
>3.5b2
Thanks. will try it out: the starting tutor in the docs had not
mentioned anything about max_gradient - though I remember reading
something about it elsewhere - perhaps in your tutorial (just glance
dthru it - wanted to practice it after this)
camera.
Have already d'led it: will go thru it properly.Thanks again
-Anoop
