"Anders K." <and### [at] f2s com> wrote in message news:3ba7bbdd$1@news.povray.org...
> No, but why would ActiveX change the place in the page that the links point
> to?
HTML Help uses an ActiveX control in the index pane, and the symptom of having
it disabled (at least for one pre-beta tester) was exactly as you described.
Entries would take you to the top of a page but never to a point within it.
What is your version of IE ?
-- Chris
having
described.
it.
Oh; that's not exactly what I was saying. For example, with #break in the
index, the link currently points to position [B] below; I think it should
point to position [A] so you can see the heading.
[A] 6.2.6.3 The #switch, #case, #range and #break Directives
[B] A more powerful conditional is the #switch directive. The syntax is as
follows...
But I guess Ingo has a reason for pointing it to [B]. That's fine; it
doesn't really matter that much.
IE 6.0, HTML Help 1.3.
Anders
This is just the way the doc generator works. I'd like to change it but it's
not trivial. I'll see what I can do.
-- Chris
On Tue, 18 Sep 2001 17:26:03 -0400, "Anders K." <and### [at] f2s com>
wrote:
>> > Lots of the index links take me just below a section heading. For
>> > example, the first entry in the index, "#break". Shouldn't they take
>> > me just above the section heading instead?
>> Do you have ActiveX disabled ?
>to?
I get the same sort of behaviour. The index link for "pi" is even
worse. It seems to make no difference whether I enable ActiveX or not.
I must admit that until I installed POV 3.5, I didn't use Internet
Exploder for anything, and I only installed IE5 to have access to the
POV help files. I saw several settings in the "Internet Security"
menus that affected ActiveX. I tried changing all of them, and I
couldn't change the behaviour of POV's help system. I suppose it's
possible that I didn't change the proper setting in some menu,
somewhere, but I doubt it.
<The following is margainly on topic for this thread, but I felt it
needed to be said.>
For what it's worth, I really don't like having POV-Ray rely on
Internet Explorer at all. My computer and I lived very happily without
IE5, and had intended to do so for the rest of eternity - until POV
3.5 for Windows came out, at least.
It's almost as bad as when I recently tried to update Norton
Anti-Virus and it wanted me to install some sort of Windows Scripting
(or something like that), just so Norton Anti-Virus could protect me
from it! Now I can't upgrade my virus checker any more, without adding
this additional Microsoft "junk" software to my system, which I'll
never use, only so Norton can try its best to protect me from it.
Overall, The POV-Team has done an excellent job with POV-Ray for
Windows 3.5, and I certainly appreciate their efforts. I just wanted
to be on record as not appreciating this particular aspect of the
POV-Ray help implementation.
Thanks for reading,
Glen
I don't think this is really a bug. In the case if pi, I think it would be
better if the link pointed to 6.1.3.4.1, Constant Identifiers, so that you
can see the whole definition of pi, not just what it's used for. But it
really doesn't matter that much.
Well, you can complain to Microsoft; they abandoned enhancing or fixing their
old help system (which is FULL of bugs) many years ago. HTML Help is their
'official' help system now, and it depends on IE ...
So, really, we have no choice (using the old help format for any sort of
sophisticated help is just too painful, unless you have an expensive add-
on toolkit of some sort, and even then, it's not crash-hot).
-- Chris
Microsoft: because choices are confusing.
<chuckle>
May I use this for my .signature ?
Jan Walzer <jan### [at] lzer net>
"Jan Walzer" <jan### [at] lzer net> wrote in message news:3baa26c6$1@news.povray.org...
sure ... I didn't invent it myself, I saw it somewhere sometime and it just stuck
in my mind.
-- Chris
I tried an internal modem once, but it hurt when I walked.
I know this is a really old thread, but several of these doc bugs are still
here in beta 9.
> When I double-click on most of the index items, the "Locate",
> "Previous", and "Next" buttons become disabled, which is slightly
> annoying.
> In Section 6.0, "Scene Description Language":
> > For details on those five items see section "Language Directives",
> > section "Objects",
> The link here only includes Object and not the s, and the link points
> to "References to 'object'", instead of section 6.5 as it should.
> In Section 7.13.4, "shapesq.inc":
> > Bicorn
> > y^2 - (x^2 + z^2) y^2 - (x^2 + z^2 + 2 y - 1)^2 =
> Equals what? :-)
> In Section 7.18.3, "Woods:" (the colons from these section titles
> probably shouldn't be here, for consistency):
> > Dark_Wood
> > Dark wood with a,ish hue to it.
> Huh? :-)
> MISSING HTML LINKS
> In these cases, the text pointed to should probably be a link, but
> isn't.
> In Section 1.11.8, "Bug Reporting via our News Server"
> > See http://www.povray.org/groups.html for information about [...]
> In Section 8.2.1, "Contacting the authors":
> > [...] via the internet at http://www.povray.org/.
> In Section 8.3.1.3, "Apple Macintosh" (the section title appears to
> contain a double space):
> > Apple's web site <http://developer.apple.com/sdk/>
> In Section 8.3.2.1, "World Wide Website www.povray.org"
> > For more information about the server see
> > http://www.povray.org/groups.html.
> In Section 8.3.2.2, "Books, Magazines and CD-ROMs"
> > You can always find the latest information on what is available at
> > our web site www.povray.org.
> PRESENT TENSE REFERENCES TO EARLIER VERSIONS
> In Section 3.4.13, Text Object:
> > Now, for POV-Ray 3.0, a new primitive has been introduced that can
> > use any TrueType font to create text objects.
> In Section 6.2.2.1, "Declaring identifiers" (should this be
> capitalized?), and Section 6.2.5, "The #version Directive":
> > This semi-colon is introduced in POV-Ray version 3.1.
> In Section 6.5, "Objects":
> > The "Interior" is a feature introduced in POV-Ray 3.1.
> In Section 6.6, "Interior":
> > Introduced in POV-Ray 3.1 is an object modifier statement called
> > interior.
Anders
light_source{6#macro A(B)#declare C=mod(E B);#declare E=(E-C)/B;C#end
#macro B(E)#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(C<3)cylinder
{0(C=<1 2>).2translate<D+C*A(2)A(4)#else intersection{torus{1 .2}box{
-y 2}rotate<-1 0C+1>*90translate<D+1A(2)*2+1#end-2 13>finish{specular
1}pigment{red 1}}#end#end#end#local D=-8;1}B(445000298)B(519053970)B(
483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)
