POV-Ray : Newsgroups : povray.beta-test : [SOR] Bug still there ... Server Time
7 Mar 2026 16:22:09 EST (-0500)
  [SOR] Bug still there ... (Message 1 to 4 of 4)
Subject: [SOR] Bug still there ...
Date: 14 Sep 2001 06:41:25
Message: <3ba1ded5@news.povray.org>
I repost this one, as it seems there are no furter comments to it ...
This also happens on Beta 2
I can't see why the following scene won't render when changing "Value" to 1.5
or lower ...
background{
color rgb <1,1,1>
camera{
 location<-2.5,0,5>
 look_at<-2.5,0,0>
    sor {
        #declare Value=0.2
       5,
       <0.0,   -1.0>
       <0.0,   -0.5>
       <Value,   0.5>   // <------ change Value to 0.15 or lower ... and see
       <0.3,   1.0>
       <0.4,   1.5>
       rotate z*90
        pigment{color rgb 1}
light_source{
<100,100,100>
color rgb <1,1,1>
Jan Walzer <jan### [at] lzernet>
Subject: Re: [SOR] Bug still there ...
Date: 28 Sep 2001 00:27:33
Message: <3bb3fc35$1@news.povray.org>
"Jan Walzer" <jan### [at] lzernet> wrote...
>     sor {
>         #declare Value=0.2
>        5,
>        <0.0,   -1.0>
>        <0.0,   -0.5>
see
It is possible that the first two points, combined with a third point with a
height of 0.15, will cause the cubic spline to dip below a height of 0.0.
That would cause problems for the root solver.  Render with the values below
to see how the curve is concave, and how two zero-height points could cause
the SOR height to drop below 0.0.
Therefore, this is not really a bug, but a strange limitation of the SOR
object.
-Nathan
    sor {
        #declare Value=0.1
       5,
       <0.013,   -1.0>
       <0.013,   -0.5>
       <0.3,   1.0>
       <0.4,   1.5>
       rotate z*90
        sturm
Date: 28 Sep 2001 10:20:14
Message: <slrn9r91ov.5an.ron.parker@fwi.com>
>>     sor {
>>         #declare Value=0.2
>>        5,
>>        <0.0,   -1.0>
>>        <0.0,   -0.5>
>see
>object.
It might be a bounding thing, too.  I'm not sure the bounding routines really
care for negative-radius cylinders.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 28 Sep 2001 10:28:38
Message: <slrn9r928n.5an.ron.parker@fwi.com>
>>>     sor {
>>>         #declare Value=0.2
>>>        5,
>>>        <0.0,   -1.0>
>>>        <0.0,   -0.5>
>>see
>>object.
In fact, having just gone through the bcyl routines looking for the other
SOR bug, I can testify that they do not like bounding cylinders where the
curve crosses 0, and are VERY likely to fail to render large chunks of the
part of the spline contained in such an interval.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
