POV-Ray : Newsgroups : povray.beta-test : Confused about "waves" Server Time
19 May 2026 07:21:34 EDT (-0400)
  Confused about "waves" (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Confused about "waves"
Date: 14 Sep 2001 10:17:14
Message: <3ba2116a@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
:>  function 300,300
:>   pigment
: Unrelated to your problem, I am wondering why you are using a pigment here.
: A pattern would be much easier to control...
  Also unrelated, but this made me remember one thing:
  Can image functions be declared? I remember trying it once but not
succeeding (IIRC it issued an error at the first number).
Date: 14 Sep 2001 11:14:04
Message: <3ba21ebc$1@news.povray.org>
In article <3ba2116a@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
You should be able to write a function and call it just the same way as you
call functions in isosurfaces:  function { foo(x,y,z) }
    Thorsten
e-mail: tho### [at] trfde
Date: 14 Sep 2001 11:41:24
Message: <3ba22523@news.povray.org>
: You should be able to write a function and call it just the same way as you
: call functions in isosurfaces:  function { foo(x,y,z) }
  What I mean is that if I write something like this:
#declare MyImageFunction = function 256,256 { pattern { ... } }
I get an error at the first '256' (if I remember correctly; I can't confirm
this right now as I'm not at home).
  PS: It might be that it works and that I just typoed somewhere (eg. forgot
the comma or something), and if this is so, just ignore this... :)
  I'll get home soon and test it again.
Date: 14 Sep 2001 12:02:40
Message: <3ba22a20@news.povray.org>
In article <3ba22523@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Well, you write
 #declare MyImageFunction = function { pattern { ... } }
 height_field
  function 256, 256 { MyImageFunction(x,y,z) }
which is exactly what the syntax description in the docs says.
I don't see why one would declare an image and be surprised that is doesn't
work (as that is what your example tries to do) - it isn't possible at all
with any image map type and never has been...
    Thorsten
Date: 14 Sep 2001 12:56:04
Message: <3ba236a4@news.povray.org>
here.
Something which I do not see in the docs is an explanation about how to
properly use 'pattern' in a 'function'. You don't say whether or not it will
be grayscale. Or maybe I just totally missed it.
Date: 14 Sep 2001 14:18:27
Message: <3ba249f3@news.povray.org>
In article <3ba236a4@news.povray.org> , "Tony[B]" <ben### [at] catholicorg>
Oh, good point.  The documentation kind of assumes you know that the pattern
functions are return a scalar, not a vector, and thus a pattern is
grayscale.  Maybe the docs should explain the difference between pigment and
pattern functions better, in particular for the image-map-function ... Ingo,
are you reading this?
    Thorsten
Date: 14 Sep 2001 14:34:27
Message: <Xns911CD14ACA15Aseed7@povray.org>
in news:3ba249f3@news.povray.org Thorsten Froehlich wrote:
> Ingo,
Yes
Ingo
Date: 14 Sep 2001 14:52:04
Message: <3ba251d4@news.povray.org>
In article <Xns### [at] povrayorg> , ingo <ing### [at] homenl>
wrote:
>> Ingo,
> Yes
Could you add a scentence or two in the function-image-type section that
explains that a pattern function will be easier to use for a function-image
compared to a pigment function which generates an unnecessary color
information that is useless when the function-image is used for a
height_field.
    Thorsten
Date: 14 Sep 2001 14:52:13
Message: <3ba251dd$1@news.povray.org>
wrote:
>> Ingo,
> Yes
height_field.
And maybe try to make it a bit more clear that a pattern function returns a
scalar and a pigment function returns a color vector (I am not sure how and
where to add this though).
    Thorsten
Date: 14 Sep 2001 16:37:46
Message: <Xns911CE63267467seed7@povray.org>
> returns a scalar and a pigment function returns a color vector (I
> am not sure how and where to add this though).
I'll figure out something.
Ingo
