POV-Ray : Newsgroups : povray.beta-test : Help clarification for pigment functions in isos Server Time
14 Oct 2025 06:41:15 EDT (-0400)
  Help clarification for pigment functions in isos (Message 1 to 5 of 5)
Subject: Help clarification for pigment functions in isos
Date: 13 Sep 2001 10:59:04
Message: <3ba0c9b8@news.povray.org>
6.5.4.2  Functions in Isosurface
#declare FBozo = function { pigment { bozo color_map { [0 rgb 0] [1 rgb 1] }}}
isosurface {
  function  { FBozo(x,y,z).gray }
Although correct, wouldn't this be better as:
isosurface {
  function  {y - FBozo(x,0,z).gray }
or similiar?
#macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
}light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
Subject: Re: Help clarification for pigment functions in isos
Date: 13 Sep 2001 11:41:27
Message: <Xns911BB3F65AF37seed7@povray.org>
Why?
Ingo
Date: 13 Sep 2001 12:14:38
Message: <3ba0db6e$1@news.povray.org>
"ingo" <ing### [at] homenl> wrote in message
news:Xns### [at] povrayorg...
> Why?
Because, and I may be doing something stupid, the following does not actually
render anything as far as I can see...
#declare fn_floor= function{pigment{bozo color_map{[0 rgb 0][1 rgb 1]}}}
isosurface {
  function {fn_floor(x,y,z).gray}
  max_gradient 7
  contained_by {box{<-10,-10,-10>,<10,10,10>}}
  accuracy 0.1
  evaluate 1, 1.2, 0.99
  pigment{rgb 1}
  finish{ambient 1}
Date: 13 Sep 2001 13:55:56
Message: <BdvbKGAYMPo7EwkD@econym.demon.co.uk>
>> Why?
>isosurface {
>  max_gradient 7
>  accuracy 0.1
>  pigment{rgb 1}
>  finish{ambient 1}
Because, of course, the specified pigment takes values that are greater
than zero everywhere (using the new default noise_generator settings -
bozo using the old noise algorithm had plateaus at zero) and the default
threshold is zero. The surface only exists at points where the function
is equal to the threshold, and that doesn't happen.
An alternative fix would be to specify something like "threshold 0.5",
but that's a bit of a boring surface.
Mike Williams
Gentleman of Leisure
Date: 14 Sep 2001 04:21:38
Message: <3ba1be12@news.povray.org>
"Mike Williams" <mik### [at] nospamplease> wrote in message
news:Bdv### [at] econymdemoncouk...
Aha/Doh!
Boring I can live with, visible would be nice... what about
isosurface {function {fn_floor(x,y,z).gray - 0.1}
... which would avoid upsetting any threshold purists...
