POV-Ray : Newsgroups : povray.beta-test : POVMS_ASSERT failed in D:\povray\3.5\source\povms.cpp Server Time
7 Mar 2026 16:32:37 EST (-0500)
  POVMS_ASSERT failed in D:\povray\3.5\source\povms.cpp (Message 1 to 2 of 2)
Subject: POVMS_ASSERT failed in D:\povray\3.5\source\povms.cpp
Date: 10 Sep 2001 23:20:51
Message: <3b9d8313$1@news.povray.org>
A new situation. I don't know if this is a bug but it's a new message.
OS Windows ME 4.90 Build 3000
Intel PIII 650, 384 meg ram
This new error message occurs when running current beta from inside
Windows Scripting Host using the command line:
"D:\Program Files\POV-Ray for Windows v3.5\bin\pvengine.exe"
 d:\wyrmv10\pov\povini.ini
 +Id:\wyrmv10\pov\beamexample.pov
as a string. the following error message occurs. The render itself
completes.
POV is set to exit on completion.
 line 178: POVMS_Deinitialize called but POVMS is not initialize
 Nigel.
Subject: Re: POVMS_ASSERT failed in D:\povray\3.5\source\povms.cpp
Date: 11 Sep 2001 01:29:29
Message: <slrn9pr89t.hlh.ron.parker@fwi.com>
Thanks for bringing this one to our attention.  I had found it myself
earlier this evening while working on another problem, and it should be
fixed now.  Whether the fix will make it into the next beta is unsure at
this time, but it will be fixed in due course.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
