POV-Ray : Newsgroups : povray.beta-test : unclosed function image type Server Time
17 May 2026 20:28:26 EDT (-0400)
  unclosed function image type (Message 1 to 3 of 3)
Subject: unclosed function image type
Date: 10 Sep 2001 07:16:34
Message: <3b9ca112$1@news.povray.org>
Playing for first time with the new function image type, and being so bad
closing sentences, I tried to parse this code:
height_field{
    function 128,128{
        pigment{
            bozo
            color_map{
                [0.00 rgb 0]
                [1.00 rgb 1]
        /* here is missing a closing bracket */
    translate -.5
And got :
  Parse Error: No matching } in '{', translate found instead
When it should read:
  Parse Error: No matching } in 'function', translate found instead
...isn't?
 P.S.: Also, it sometimes hanged POV when the editor tried to highlight the
line containing the error (which was not highlighted when POV hanged).
Jaime Vives Piqueres
POV-Ray for Windows 3.5 beta 1
W98SE on AMD Athlon 1.2Ghz, 256MB SDRAM,  >50Db CPU fan.
Subject: Re: unclosed function image type
Date: 10 Sep 2001 07:38:01
Message: <3b9ca618@news.povray.org>
By the way, I think it should be made clear in the documentation that using
a pattern in an image function is more efficient than using a pigment.
  Why? Because a pattern creates a b/w image while a pigment creates a color
image, which is (I suppose) 3 times bigger (ie. it takes 3 times more memory).
Date: 10 Sep 2001 07:59:18
Message: <3b9cab16@news.povray.org>
news:3b9ca618@news.povray.org...
using
color
memory).
 Ah! Yes, I see: 6.1.6.1. Not read this before, I was only converting an old
"pigment_pattern" from megapov.
(I read the docs "on the fly"). But you are right: a quick test revealed
that it uses half the memory needed with a pigment (not 1/3, tough).
 Thanks!
Jaime
