POV-Ray : Newsgroups : povray.beta-test : [Win] Save_as destroys original file Server Time
28 Apr 2026 23:37:25 EDT (-0400)
  [Win] Save_as destroys original file (Message 11 to 18 of 18)
Subject: Re: [Win] Save_as destroys original file
Date: 8 Sep 2001 15:50:15
Message: <3b9a7677@news.povray.org>
: > I can confirm that a save_as results in two duplicate files under Win 98.
: > All changes are retained across both files.
: For what it is worth the behavior is the same in POV-Ray v3.1g. I wonder
: why no one noticed this before.
: Ken Tyler - POV-Ray Techncial Assistance Group
I have had that happen under 3.1 also but thought I had
somehow screwed it up myself.  It was quite some time
before I went back to rerun the original file and by then
I was no longer certain of how I had saved the new file.
Win 98.  Haven't yet confirmed this with 3.5.
Y
Date: 8 Sep 2001 16:00:58
Message: <3b9a78fa$1@news.povray.org>
"Dave Dunn"  wrote
: The file destruction was definitely true in 3.1, as it is in 3.5. I guess I
: stopped noticing it when I got myself in the habit of saving the file under the
: new name *before* making any changes. But now that you mention it, it would be
: nice if it didn't do that.
: 1G Athlon
: Win ME
Exactly the reason I forgot about it too ...
Turning Auto-Reload to 'Never" does correct this but I'm
not certain what feature I lose by doing that.
Y
Win 98 Pov3.5b1
Date: 9 Sep 2001 00:30:00
Message: <3b9af048@news.povray.org>
"Y" <out### [at] huntelnet> wrote in message
news:3b9a78fa$1@news.povray.org...
guess I
under the
would be
Well, well, well.  That explains my messed up camera Insert menu text files!
I knew I had done it right but I was going from file to file by using Save
as... after each edit.
Ha ha, Auto Reload is set to Ask here.  So what I must have been doing is
answering OK or Yes to the question each time.  And I do remember something
like that going on now.  I think I usually say not to reload, figuring on
the reasoning I know the file doesn't need to be.  Actually without really
knowing what I was ever doing too, so now I understand that for certain.
Thanks to you guys.
No telling what files I scrambled besides over time; no matter I suppose, as
long as those bak files are intact after the fact.
Bob H.
Date: 9 Sep 2001 00:34:44
Message: <3b9af164@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message news:3B9A6136.A17E7C8D@pacbell.net...
> > Can you try turning Auto-Reload to 'Never' and see if it still happens ?
> That changed it to the expected behavior. Bug or do I need to RTFM ?
I don't know if it's a bug in POVWIN, but it's not RTFM either. Somehow doing a
'Save As' under Win98 causes POVWIN to lose focus (perhaps only for a very short
time), and this triggers the automatic saving of the file as documented in the
section on Auto-Reload.
I'll have to see if I can work out why it's losing focus.
-- Chris
Date: 9 Sep 2001 02:23:40
Message: <3b9b0aec$1@news.povray.org>
"Chris Cason" <newsadmin@-despam-povray.org> wrote in message
news:3b9af164@news.povray.org...
doing a
short
the
> -- Chris
I've noticed this with programs other than POVWIN.  It happens most often
when closing sub-windows.  For instance, sometimes POVWIN will lose focus to
another program (which is brought to the top) when I close the render
window.  At first I thought it was just POVWIN, but I've noticed (since I
began paying attention) that it happens in many of the programs I have that
has subwindows that can be closed.  That leads me to believe it's a Windows
issue.
Michael
(POV-Ray 3.5 beta 1, Windows, Athlon 750, 196 MB RAM)
Date: 9 Sep 2001 04:23:43
Message: <3b9b270f@news.povray.org>
It's a bug at least in a way, 'cause it should ask to re-load the file if
it's configured (Auto-Reload set to "ASK") that way. But there is no such
question!
Marc-Hendrik
Chris Cason schrieb in Nachricht <3b9af164@news.povray.org>...
Date: 9 Sep 2001 08:12:31
Message: <3b9b5caf@news.povray.org>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in message
news:3b9b270f@news.povray.org...
> question!
You didn't read the original message (or you didn't read the docs; your pick).
The problem is not that the external file has been changed, but that it has been
saved. The docs say nothing about being asked to save the file if auto-reload
is set to 'ask'.
Are you able to understand this, or do I need to explain it another way ?
Date: 9 Sep 2001 08:37:22
Message: <3b9b6282@news.povray.org>
I'm able to understand this and I'll shut up for now. Sorry, didn't want to
insist in anything.
Marc-Hendrik
Chris Cason schrieb in Nachricht <3b9b5caf@news.povray.org>...
