POV-Ray : Newsgroups : povray.beta-test : blob problem Server Time
15 Jun 2026 02:42:55 EDT (-0400)
  blob problem (Message 1 to 6 of 6)
Subject: blob problem
Date: 7 Sep 2001 13:34:36
Message: <3b99052c@news.povray.org>
Actually this is something I have already noticed in POV 3.1 and once
reported to p.g but it did not get much attention. Try the following:
background{White}
camera{
  angle 15
  location <0,.2,-1.0>
  look_at <0,0,0>
light_source{ <10,20,-10> color White}
blob {
  threshold .65
  sphere{ <.05,0,0>,.08,1 pigment{Blue}}
  sphere{ <-.05,0,0>,.08,1 pigment{Pink}}
  finish{phong 1}
sphere{<.05,0,0>,.08
  pigment{Yellow transmit .95}
sphere{<-.05,0,0>,.08
  pigment{Green transmit 1}
This is basically the example from section 3.4.2. just scaled by a factor
.1 and the spheres made more transparent. When you render it you see that
there is a part from the blob missing where the sphere intersects it!
This effect gets worse when you scale the scene down more. I know that
POV-Ray is known to behave strange when you use extremely small values  but
I think .08 isn't that small (the effect is even noticeable with the
original sample scene if you render it at high resolution).
Actually I have found some kind of fix to the problem. As there was no
response to the problem when I reported it I had a look at 'blob.c' from
the source and found the magic constant 'DEPTH_TOLERANCE' which is by
default set at 1.0e-2. I decreased the value to 1.0e-5 and the effect
became barley visible any more. I must admit that I have no idea what this
constant actually is good for... but I think somebody who knows about it
should rethink the value (as it seems still be the same in pov 3.5).
One could even decrease this value more... but I though doing it just a
little would saver. I have used a version with this correction for quite
some time now and I have not recognised any problems or an increase in
render time.
Blobs generally seem to have problem with very small radii, try e.g.
background{White}
camera{
  angle 15
  look_at <0,0,0>
blob {
  threshold .65
  sphere{ <.0005*4,0,0>,.0008*4,1 pigment{Blue}}
  sphere{ <-.0005*4,0,0>,.0008*4,1 pigment{Pink}}
  finish{phong 1}
  scale 100/4
Not much of the original blob left :( Changing the constant mentioned above
does not help. I can life with that as this is only the case if radii get
really small. Maybe a note in the docs?
Well, as I checked the docs again for blobs I found something strange:
In section 3.4.2 there are references to scene files named 'blobdemoX.pov'
(X=1..4). Hmm.. fine I thought and wanted to load them - but I nowhere
found them in the scenes directory. I thought one was probablly to create
these files oneself as said sometimes. While sometimes it is clearly 'Now
we create a scene file named ...', sometimes the docs say 'see xxx.pov'
which means for me that this file comes together with the distribution.
Then I had a look at other sections in 3.x and found even more references,
e.g. to 'lathdem1.pov', and most clearly at the end of 3.4.6:
'More complex examples,'...'can be found under the scene directory as
chesmsh.pov and robotmsh.pov.'
I can find chesmsh.pov but nowhere robotmsh.pov. Wondering about all that I
thought the files were just missing in the beta 3.5... and I had a look at
the pov 3.1 files. But it is missing there as well! Is this known or
intentionally or ...??
My system:
Intel PIII800Mhz, vmware for linux emulating win95, 512MB RAM.
- Micha
Subject: Re: blob problem
Date: 7 Sep 2001 13:51:19
Message: <Xns9115C9FA85DCAseed7@povray.org>
> strange: In section 3.4.2 there are references to scene files named
> 'blobdemoX.pov' (X=1..4). Hmm..
I think these files have been renamed in 3.1 in the scenes/object
directory are files blob.pov blob1a-c.pov, lathe1a-c.pov. I'll try and
find out if these are the right files and then make the changes.
As to the blob bug, it is a known issue.
Ingo
Date: 7 Sep 2001 14:34:06
Message: <3b99131e@news.povray.org>
I forgot to mention. I have tried those. They are nice examples but not the
ones from the docs section 3.
There was a question mark after 'blob bug' in your 'know issues in 3.5'
post so I thought posting a specific example might help.
- Micha
Date: 7 Sep 2001 17:45:43
Message: <Xns9115F1B7F1DB0seed7@povray.org>
> not the ones from the docs section 3.
Noticed that. Well, lets turn it into a hands on tutorial :)
Ingo
Date: 7 Sep 2001 21:20:40
Message: <3B99734E.20B86A7C@pacbell.net>
I've got copies of the original blobdem(x).pov files if you want them.
There are from the POV-Ray v3.0 distribution. I haven't looked at
them yet but I doubt there any problems with getting them to render
in v3.5.
Ken Tyler
Date: 8 Sep 2001 08:05:39
Message: <Xns91168F5FD3F5seed7@povray.org>
> them.
No, thanks Ken.
Ingo
