POV-Ray : Newsgroups : povray.beta-test : [function pattern] Server Time
17 May 2026 21:46:43 EDT (-0400)
  [function pattern] (Message 1 to 3 of 3)
Subject: [function pattern]
Date: 7 Sep 2001 12:00:25
Message: <3b98ef19@news.povray.org>
the following gives an error ...
#declare P2=function {pattern {crackle solid}}
#declare G=
    function
        #local Faktor=<1,1,1>*0.75;
        P2(x*(Faktor.x+0),y*(Faktor.y+0),z*(Faktor.z+0))
    }  //     ^^^^^^------ Expected 'operand', vector function 'vector
identifier' found instead
Am I wrong ?
BTW: the parentheses and the "+0" is only because I tried to force some
"casting" ... it seems there is no such way ...
Jan Walzer <jan### [at] lzernet>
Subject: Re: [function pattern]
Date: 7 Sep 2001 12:07:05
Message: <3b98f0a9$1@news.povray.org>
"Jan Walzer" <jan### [at] lzernet> wrote in message
news:3b98ef19@news.povray.org...
> #declare G=
>     function
Someone else probably has a better answer, but I noticed this too.  It seems
the operand *must* be declared as an operand before being used in the
function, i.e.,
#local Fx=Faktor.x;
#local Fy=Faktor.y;
#local Fz=Faktor.z;
P2(x*(Fx+0),y*(Fy+0),z*(Fz+0))
I don't know the reason though
-tgq
> Am I wrong ?
Date: 7 Sep 2001 14:27:34
Message: <3b991196@news.povray.org>
In article <3b98f0a9$1@news.povray.org> , "Trevor Quayle"
> function, i.e.,
> #local Fx=Faktor.x;
Yes, unfortunately this is required right now.  I am not sure this will get
changed in 3.5 because it has to do with handling vectors in function which
isn't supported in 3.5.  It will change in 4.0 of course and I will look
into allowing at least such a simple case in 3.5.
    Thorsten
e-mail: tho### [at] trfde
