POV-Ray : Newsgroups : povray.beta-test : Scale in function pattern ? Server Time
26 Jul 2026 13:59:52 EDT (-0400)
  Scale in function pattern ? (Message 1 to 8 of 8)
Subject: Scale in function pattern ?
Date: 7 Sep 2001 09:46:20
Message: <3b98cfac@news.povray.org>
Sorry for not finding in the docs ...
In the example source I can change the marked scale-value without any
effect...
But as the parser accepts it, it can't be completely wrong, can it ?
If it's wrong, is there another way to set the "scale" of the structure in
the function G ?
#declare FP=
    function {
        pattern {
            gradient 1
#declare G=
    function {
        pattern {
            crackle solid
            scale 0.1    // <---- No effect !
#declare MyPFkt=
    function {
        FP(x+G(x,y,z)*1,y+G(x,y,z)*1,z+G(x,y,z)*1)
plane { -z,-30
    finish {
        ambient 1
        function {
            MyPFkt(x,y,z)
        color_map {
            [0,rgb z]
            [1,rgb x+y]
Jan Walzer <jan### [at] lzernet>
Subject: Re: Scale in function pattern ?
Date: 7 Sep 2001 09:55:22
Message: <slrn9phkeb.55q.ron.parker@fwi.com>
>effect...
I think this is a known bug.
>the function G ?
#declare G1=function {pattern{crackle solid}}
#declare G=function{G1(x*10,y*10,z*10)}
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 7 Sep 2001 10:19:04
Message: <3b98d758@news.povray.org>
> >effect...
> >the function G ?
wouldn't it be simpler to implement the scale-keyword in the right way ?
Date: 7 Sep 2001 10:37:02
Message: <slrn9phmsf.56v.ron.parker@fwi.com>
>> >effect...
>> >the function G ?
Of course.  It will be fixed.  I thought you were asking for a workaround.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 7 Sep 2001 10:40:59
Message: <3b98dc7b@news.povray.org>
Jan Walzer <jan### [at] lzernet> wrote:
: wouldn't it be simpler to implement the scale-keyword in the right way ?
  He said it's a known bug. This means the behaviour is not by design.
Date: 7 Sep 2001 12:00:22
Message: <3b98ef16@news.povray.org>
I wasn't sure which behaviour was meant ...
The behaviour of the parser, that (in this case) wrong code is accepted, or
the behaviour that the accepted, right code has no effect ...
of course ... it's clear now ...
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:3b98dc7b@news.povray.org...
Date: 12 Sep 2001 21:42:53
Message: <3BA00EF0.FA25CA2B@geocities.com>
Perhaps he's been burned by too much dealing with Adobe. Where  "a known bug"
translates to "sure, it's broken, whacha going ta do, sue us?"
Wind the Frog!
Date: 13 Sep 2001 06:09:42
Message: <3ba085e5@news.povray.org>
Jon A. Cruz <jon### [at] geocitiescom> wrote:
: Perhaps he's been burned by too much dealing with Adobe. Where  "a known bug"
: translates to "sure, it's broken, whacha going ta do, sue us?"
  I think that the process is longer:
  The first response is: "The problem is not in our software but in yours/you".
  When that doesn't work: "Ok, it's broken, live with that."
  Then, as time passes: "New version of our magnificent program with huge
improvements, only at $10000000!".
