POV-Ray : Newsgroups : povray.beta-test : Question: Output folder Server Time
17 May 2026 21:46:42 EDT (-0400)
  Question: Output folder (Message 1 to 6 of 6)
Subject: Question: Output folder
Date: 6 Sep 2001 20:52:58
Message: <3b981a6a$1@news.povray.org>
In WinPov 3.1 in the installer there was an option for setting a default
render directory for all images, I found this very handy, now it seems you
have to set this by hand.
Subject: Re: Question: Output folder
Date: 7 Sep 2001 01:53:55
Message: <3b9860f3@news.povray.org>
"Thomas Lake" <tla### [at] homecom> wrote in message news:3b981a6a$1@news.povray.org...
This feature caused support problems (folks set it, forgot it, then complained
that they couldn't find their output files ...)
So it's been removed and I don't think I'll put it back. It's not too hard to
set it by hand in the master INI file, after all ... (don't forget to add it
to the IO restrictions setup if you do).
-- Chris
Subject: Re: Another Output folder Question
Date: 7 Sep 2001 11:50:56
Message: <3b98ece0@news.povray.org>
: This feature caused support problems (folks set it, forgot it, then complained
: that they couldn't find their output files ...)
: So it's been removed and I don't think I'll put it back. It's not too hard to
: set it by hand in the master INI file, after all ... (don't forget to add it
: to the IO restrictions setup if you do).
: -- Chris
Bug ??? or just a flawed brain ? ;)
I've been trying to set it like so in the INI file:
Output_File_Name=G:\Programs\POV-Ray for Windows v3.5\Images
and when I render, I get this in the message window under Output Options:
Output file: G:\Programs\\POV-Ray for Windows v3.5\Images.bmp, 24 bpp
And that's what happens ... regardless of the scene I render, the output writes
to a file *Images.bmp* in G:\Programs\\POV-Ray for Windows v3.5\
instead of writing the correctly named file into my Images folder.
Also ... I edited the PVENGINE.ini  and added #3:
[Permitted Output Paths]
1=%INSTALLDIR%\Renderer\ReRun
2=%INSTALLDIR%\Insert Menu
3=G:\Programs\POV-Ray for Windows v3.5\Images
I also have tried
3=%INSTALLDIR%\Images
and
3=%INSTALLDIR%
believing from the docs that all folders below this would be included.
 And also opted for Allow Read, Restrict Write but still get the message:
 "I/O Restriction prohibits write access to' G:\Programs\\POV-Ray for Windows v3.5\'
For 'images.bmp' "
and an option to bypass the restrictions for this render.
Where this "images.bmp"  thing comes from ... I don't know.
This seems like such a simple thing to do and I have read, re-read and re-re-read
the docs so if this isn't a bug and just me .... sorry ....  I'm an idiot ;)
I don't know what else to try other than let it write to the input folder.
Win98  SE, P200, 64MB (that's right ... don't laugh ;)
Thanks
Y
Date: 7 Sep 2001 11:54:03
Message: <3b98ed9b$1@news.povray.org>
try
3=G:\Programs\POV-Ray for Windows v3.5\Images\
and don't forget your backslash this time
-tgq
"Y" <out### [at] huntelnet> wrote in message news:3b98ece0@news.povray.org...
complained
hard to
add it
> : -- Chris
writes
> I also have tried
> and
> 3=%INSTALLDIR%
Windows v3.5\'
> For 'images.bmp' "
re-re-read
> Thanks
> Y
Subject: Re: Got it !!!
Date: 7 Sep 2001 12:09:48
Message: <3b98f14c@news.povray.org>
: [Permitted Output Paths]
: 1=%INSTALLDIR%\Renderer\ReRun
: 2=%INSTALLDIR%\Insert Menu
: 3=G:\Programs\POV-Ray for Windows v3.5\Images
Never mind ....
added the "\" at the end:
and all is well.
Sorry for the "false bug" ...
Y
Date: 7 Sep 2001 12:12:56
Message: <3b98f208@news.povray.org>
: try
: 3=G:\Programs\POV-Ray for Windows v3.5\Images\
: and don't forget your backslash this time
: -tgq
Figured it out just after sending the message ...
seems that's what it always takes ... as soon as you commit it
to test and send it off ... the "flash" comes ;)
Thanks
Y
