POV-Ray : Newsgroups : povray.beta-test : Strange partial image render behaviour in WinPov Server Time
12 Apr 2026 07:11:30 EDT (-0400)
  Strange partial image render behaviour in WinPov (Message 1 to 6 of 6)
Subject: Strange partial image render behaviour in WinPov
Date: 6 Sep 2001 11:21:46
Message: <3b97948a@news.povray.org>
Try this:
- Render something.
- Press shift and select an area of the render window with the mouse (for a
  partial render).
- Accept the two dialogs which pop up and let it render the partial image.
- Now press alt-c to go to the command line field.
- Remove the +sc, +sr, +ec and +er options.
- Press enter.
  It will still render the same partial image.
  If you now render again after this (eg. with alt-g), it will then render
ok the whole image.
Subject: Re: Strange partial image render behaviour in WinPov
Date: 6 Sep 2001 11:23:02
Message: <3b9794d6@news.povray.org>
Argh, shame on me!
  Athlon 1.2GHz, 256MB, Windows 98, POV-Ray beta1.
Date: 6 Sep 2001 12:15:31
Message: <3B97A119.F8186758@sycomore.fr>
I can reproduce it. Don't forget to shift-click when doing
the selection.  ;-)
Warp, did you notice this in the Messages window?
Render #1: nothing special
Render #2: Rendering using command line '+sc0.255859 +sr0.140625 +ec0.423828
+er0.307292'.
Render #3: Selected render region is '+sc0.255859 +sr0.140625 +ec0.423828
+er0.307292'.
Render #4: nothing special
It guess that when you render the selected region, you use
the coordinates, then erase them so the next render can be
full-window.
But when you render with the command-line, you don't erase
the coordinates of the selected region, so on the next
render, WinPOV uses them. Then deletes them, of course.
Hope this helps to know you're not the only one. Is the source
code available somewhere, or can we just test the binaries?
BTW, ...
The box is a Pentium-III @ 800 MHz, with only 128 MB RAM.
Yes, "only", because it runs Windows 2000 Professionnal
(French version, service pack 2), and an instance of Oracle
and Java don't help... :-(
Adrien Beau - adr### [at] freefr - http://adrien.beau.free.fr
 Mes propos n'engagent que moi et en aucun cas mes employeurs
Date: 6 Sep 2001 12:20:18
Message: <slrn9pf8i3.9d.ron.parker@fwi.com>
As with previous betas, source will not be made available until after the
final release.  This prevents support problems by preventing unscrupulous
people from disabling the beta timeout and distributing the beta version
as if it were the final release.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 6 Sep 2001 14:26:13
Message: <3B97BF9D.9A860BA3@chello.fr>
This problem is the same in Pov-Ray 3.1 for me  !
PII 350 128 Ram windows98 .....
Martial
 http://martial.rameaux.free.fr
Date: 15 Sep 2001 11:30:28
Message: <mtk1qtk70pg0j20tovjmk3arq79vnh5qg0@4ax.com>
Confirmed. This is one is as old as the 3.1 betas. I've given up using
the rubberband select due to the resource release bug (it was fixed in
3.1e, I think) and never got to using it again, but I remember having
a habit of triple-clicking alt-g then.
Peter Popov ICQ : 15002700
