POV-Ray : Newsgroups : povray.beta-test : error in SQRT Server Time
7 Mar 2026 20:01:21 EST (-0500)
  error in SQRT (Message 1 to 7 of 7)
Subject: error in SQRT
Date: 6 Sep 2001 09:20:25
Message: <3b977819@news.povray.org>
This scene works perfectly in MegaPov. It's the *lightflow thingy* made by
Warp.
Parse Error: Expected 'operand', sqr found instead.
isosurface
{ function
/* here error occurs---> */  {
sqrt(sqr(sqrt(sqr(x)+sqr(z))-1.5)+sqr(y))-(.3+.2*sin(8*atan2(x,z))) }
  contained_by { box { -<2,.5,2.1>,<2,.7,2> } }
   max_gradient 2.41 accuracy 10^-3
  translate .5*y
  pigment {rgb 1}
scale .7}
camera { location <-2,3,-3> look_at 0 }
light_source
{ <4,5,-5> rgb 3/2
plane
{ y,0
  pigment { rgb 1 }
Subject: Re: error in SQRT
Date: 6 Sep 2001 09:24:02
Message: <3b9778f1@news.povray.org>
JRG <jrg### [at] hotmailcom> wrote:
: Parse Error: Expected 'operand', sqr found instead.
  The sqr() function doesn't exist. Use ^2 instead (it shouldn't be any
slower).
Date: 6 Sep 2001 09:24:31
Message: <slrn9peu8h.voj.ron.parker@fwi.com>
>Warp.
POV 3.5 is not MegaPOV.  POV 3.5 does not have a "sqr" function.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 6 Sep 2001 09:27:04
Message: <3b9779a8@news.povray.org>
But I tried to define a sqr macro as follows:
#macro sqr(A)
A*A
and I got
Parse Error: Expected 'undeclared identifier', sqr found instead.
"Ron Parker" <ron### [at] povrayorg> ha scritto nel messaggio
news:slr### [at] fwicom...
by
> >Warp.
L(R.x)L(R.y)0,0
else's
Date: 6 Sep 2001 09:31:15
Message: <slrn9peul5.voj.ron.parker@fwi.com>
>#macro sqr(A)
>A*A
>#end
>and I got
What if you define it as a function instead, since that's what you really
want?
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 6 Sep 2001 11:11:37
Message: <3b979229@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: What if you define it as a function instead, since that's what you really
: want?
  Actually this has been done already: f_sqr() in math.inc.
Date: 6 Sep 2001 11:24:39
Message: <3b979537@news.povray.org>
In article <slr### [at] fwicom> , ron### [at] povrayorg (Ron
>>#macro sqr(A)
>>A*A
>>#end
>>and I got
> want?
I would not recommend using a function for such a simple case.  It will work
for sure, but there is some overhead involved that (if used carelessly) can
slow down rendering of isosurfaces a lot.  The built-in operators should be
used whenever possible as they offer by far the best performance.
    Thorsten
e-mail: tho### [at] trfde
