POV-Ray : Newsgroups : povray.beta-test : isosurface changes Server Time
15 Mar 2026 12:39:32 EDT (-0400)
  isosurface changes (Message 1 to 10 of 10)
Subject: isosurface changes
Date: 5 Sep 2001 06:41:19
Message: <d7tbptsuehnfm92j46nja3ofj1lhh5d0vo@4ax.com>
I see that contained_by has changed in such a way that the container
shows up at boundaries. I have a cylindrical object contained by a
box. Squares appear at the ends, whilst in Mega cylindrical ends are
traced. Feature or bug?
#declare kurvatur=.4*e;
#declare segmentL=.5;
#declare Rad=0;
isosurface {
    function { kurvatur*sqrt( cos(x/segmentL) )+y^2+z^2-Rad }
    threshold 1
    max_gradient 5.284
    accuracy 0.01
    contained_by{box{-<.79,1,1>,<.79,1,1>}}
    pigment { rgb 1 }
    finish {phong 0.5 phong_size 10}
    scale <1+e,1,1>*.5
ICQ 74734588
Subject: Re: isosurface changes
Date: 5 Sep 2001 07:08:20
Message: <3B9607A1.14F0545B@atosorigin.com>
May I say: RTFM !! (section 6.5.4)
open When the isosurface isn't fully contained within the contained_by object,
there will be a cross section. Where this happens, you will see the surface of
the container. With the open keyword, these cross section surfaces are removed.
The inside of the isosurface becomes visible. Note that open slows down the
render speed. Also, it is not recommended to use it with CSG operations.
But there is nevertheless a bug, because adding 'open' do not work too much
(the cross section is not illuminated, but still cast shadows and block
background.
Updated pov-scene (complete), the Pov-team may want to comment out the 'open'...
#declare e=exp(1);
#declare Rad=0;
isosurface {
    threshold 1
    max_gradient 5.284
    accuracy 0.001
    open
    pigment { rgb 1 }
    scale <1+e,1,1>*.5
background { rgb <1,0,0> }
camera { location <3,3,-0> look_at 0 }
light_source { 0,1 translate <6,5,4> }
 light_source { 0,1 translate <6,5,-4> }
Date: 5 Sep 2001 07:43:03
Message: <3b960fc7@news.povray.org>
news:3B9607A1.14F0545B@atosorigin.com...
much
> background.
If the container box is slightly smaller than 1.0 in that example then it
renders fine.  I have no idea though whether it's a true bug or not, just
that it could be the ever-present coincident surfaces trouble once again.
Sure looks similar since the leftover pieces aren't complete.
Bob H.
Subject: Re: isosurface changes (coincident surfaces known problem)
Date: 5 Sep 2001 07:56:17
Message: <3b9612e1@news.povray.org>
Since this group is possibly going to be visited by new POV-Ray users I
better refer to the documentation (Scene Help) about coincident surfaces.
It's mentioned a few places but the one most likely to read about it is at
3.0 Beginning Tutorial | 3.3 CSG Objects | 3.3.6 CSG Pitfalls.
Bob H.
Date: 5 Sep 2001 11:36:50
Message: <10hcpt8d5il91g8eetjijhqab2bm8lviuk@4ax.com>
<jer### [at] atosorigincom> wrote:
>May I say: RTFM !!
I did, but it didn't adress my question: _Squares_ appear at the ends,
whilst in Mega cylindrical ends are traced. This has nothing to do
with the open keyword. The iso _is_ fully contained within the box in
the "radial" direction, therefore squares shouldn't appear at the
ends, only a regular circular surface.
sig
ICQ 74734588
Date: 5 Sep 2001 12:14:49
Message: <3b964f78@news.povray.org>
It would be nice, as noted in the welcome message, if _complete_ (although
minimal) scenes would be included with bug reports. That is, one could
just copy-paste the posted scene to povray and render it and see the
bug.
Date: 5 Sep 2001 17:43:13
Message: <3b969c71@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote...
(although
> bug.
I agree!
-Nathan
Date: 5 Sep 2001 19:47:52
Message: <3b96b9a8$1@news.povray.org>
"Sigmund Kyrre Aas" <as### [at] studntnuno> wrote...
For the record, there was no bug with POV-Ray in this case.  (See my post to
Sigmund's other post.)  In this case, the user-defined function was trying
to take the square root of a negative number, which is not defined as a real
number.  I don't know why it worked with MegaPOV, because it shouldn't have.
-Nathan
Date: 5 Sep 2001 20:09:58
Message: <3b96bed6@news.povray.org>
In article <3b96b9a8$1@news.povray.org> , "Nathan Kopp" <nat### [at] koppcom>
It worked with MegaPOV functions because they had funny (and sometime
unpredictable) side effects like taking the absolute value automatically in
some cases...
    Thorsten
e-mail: tho### [at] trfde
Date: 5 Sep 2001 20:47:07
Message: <U+8uyKAgasl7Ew85@econym.demon.co.uk>
I seem to remember that there has been considerable discussion
previously on one of the povray newsgroups about the fact that MegaPOV
isosurfaces incorrectly treat the square roots of negative numbers as if
they were positive numbers.
Mike Williams
Gentleman of Leisure
