POV-Ray : Newsgroups : povray.beta-test : I can't get the insert_menu-images to render ... Server Time
7 Mar 2026 22:11:57 EST (-0500)
  I can't get the insert_menu-images to render ... (Message 1 to 6 of 6)
Subject: I can't get the insert_menu-images to render ...
Date: 5 Sep 2001 14:58:03
Message: <3b9675bb@news.povray.org>
W2k, Pov3.5b, Athlon1.3, 392MB
There are no other files in Povray open ... I see only the Message window
I go through
    Render->SelectFileAndRender->C:\Programme\Povray for Windows v3.5\Insert
Menu\images.ini
Povray stops parsing, giving me:
    Statistics Stream to console....On
    Warning Stream to console.......On
Possible Scene File Parser Initialization Error: Could not find file
'OBJECT.POV'
Scene File Parser Initialization Error: Cannot open input file
Returned from renderer with error status
Because Copy'n Paste doesn't work, I typed this by hand ... I only wrote here
the last lines I see ...
What annoyes me, is that I can't find a place, where OBJECT.POV is included
can someone describe how I have to render the Images for the insert-menu ?
Jan Walzer <jan### [at] lzernet>
Subject: Re: I can't get the insert_menu-images to render ...
Date: 5 Sep 2001 15:45:49
Message: <3b9680ed@news.povray.org>
OK .. i found something that makes me dizzy ...
I tried also to render
    C:\Programme\POV-Ray for Windows v3.5\scenes\animations\life\life.ini
Once again I got the message:
'OBJECT.POV'
When I looked into pvengine.ini I saw this:
[LastRender]
HistogramFile=
IniOutputFile=
OutputFile=C:\Programme\POV-Ray for Windows
CurrentDirectory=C:\Programme\POV-Ray for Windows v3.5\scenes\animations\life
SourceFile=C:\Programme\POV-Ray for Windows
v3.5\scenes\animations\life\OBJECT.POV
SceneFile=OBJECT
But I never specified this "OBJECT.POV" ...
Anyone else ?
Where is my mistake ?
Date: 5 Sep 2001 16:02:19
Message: <Xns9113E02FC6BD9seed7@povray.org>
> Anyone else ?
did you accidentaly delete or move povray.ini, that can be the cause.
Ingo
Date: 5 Sep 2001 16:21:51
Message: <3b96895f@news.povray.org>
> Anyone else ?
object.pov is stanard, if no other scenefile was defined with
Input_File_Name povray looks for object.pov.
Somehow there seems no inputfile specified in the ini-files you
run.
to render the insert_menu pics, do options/other
settings/re-render insert menu bitmaps if that helps
cukk
Date: 5 Sep 2001 16:29:03
Message: <3b968b0f@news.povray.org>
> > Anyone else ?
Not that I'm aware of ...
Other files render fine, and if I select
    Tools->Edit master POVRAY.INI
the file opens well ...
Date: 5 Sep 2001 17:15:22
Message: <3b9695ea@news.povray.org>
Ok ... I think my error was, that I assumed that the INI-files are prepared
in a way that they could directly be run ... not all of them are ...
