POV-Ray : Newsgroups : povray.beta-test : [doc] various Server Time
18 Jan 2025 07:30:17 EST (-0500)
  [doc] various (Message 1 to 3 of 3)
Subject: [doc] various
Date: 6 Jun 2002 07:46:31
Message: <3CFF4B98.C4BA9428@gmx.de>
"The following information is divided into eight main parts:"
should say 'nine main parts' meanwhile.
later on there are some directory references to '/usr/povray3' that should
probably be changed to '/usr/share/doc/povray35' or whatever will be the
default in 3.5 final.
references that should probably be updated.
book on that matter mentioned.  Of course you will find something in '9.'
and '10.' but it would be good IMO to update this list with some newer
books anyway.
Last updated 02 Jun. 2002 _____./\/^>_*_<^\/\.______
Subject: Re: [doc] various
Date: 7 Jun 2002 03:54:25
Message: <Xns9226655305634seed7@povray.org>
in news:3CFF4B98.C4BA9428@gmx.de Christoph Hormann wrote:
Thanks Christoph.
> should probably be changed to '/usr/share/doc/povray35' or whatever
> will be the default in 3.5 final.
I'll change it to '/usr/share/doc/povray35', unless I'm told otherwise.
Could a Mac-user tell me if the section that starts with 1) in chapter 2.5
still makese sense?
> any book on that matter mentioned.
I'll remove the link, unless...
> [...] but it would be good IMO to update this list with
> some newer books anyway.
... somebody can give me the relevant books to put in 8.4.
An update/improvement of the list is welcome.
Ingo
Date: 7 Jun 2002 04:10:01
Message: <nup0gug1rv6n3bt9qt4h0i0doka0dop4en@4ax.com>
You can link to document available on Nathan's webpage.
http://nathan.kopp.com/nk_pov_photons.zip
It is currently zip with eps but since Nathan cooperate on 3.5 you can ask him
to convert it to online PDF file.
Links (tutorials in particular) from povray.org\links could be mentioned.
POV-Ray Book projects could be mentioned.
ABX
