POV-Ray : Newsgroups : povray.beta-test : [Bug] Artefacts in lathe Server Time
17 Feb 2026 17:06:50 EST (-0500)
  [Bug] Artefacts in lathe (Message 1 to 5 of 5)
Subject: [Bug] Artefacts in lathe
Date: 27 May 2002 07:54:05
Message: <3CF21E53.DEF6128@medium.net>
Hello,
there is a bug in povray-3.5-rc5 on linux-2.4.19-pre (AMD
Duron 1000MHz): Many graphical artefacts appear.
Just see the attached scene. There are several arcs of
artefacts (one big arc below, two small arcs above).
Additionally, at the left and right border, there are some
pixels which remain black.
Is there any workaround?
Attached:
- The scene
- the corresponding makefile for linux
Medium.net Internet Server Software
Download 'us-ascii' (1 KB) Download 'pokal.v2.bug.pov.txt' (3 KB)
Subject: Re: [Bug] Artefacts in lathe
Date: 27 May 2002 08:24:59
Message: <3cf2259b$1@news.povray.org>
In article <3CF### [at] mediumnet> , Xuan Baldauf
Add "sturm" to the lathe object.
    Thorsten
PS: Please do not post attachments in this group.
Date: 27 May 2002 08:30:46
Message: <3CF226DF.C159ECE0@medium.net>
Thank you. But documentation states "In case of cubic or bezier
splines, the Sturmian root solver is always used because a 6th
order polynomial has to be solved.". I'm actually using the a
cubic spline.
>     Thorsten
Okay.
Date: 27 May 2002 08:50:23
Message: <3cf22b8f@news.povray.org>
> cubic spline.
  AFAIK the documentation is erroneous in this part.
Date: 1 Jun 2002 16:14:15
Message: <3CF947D3.ACC974AF@joplin.com>
I had a simular problem with lathe using bezier splines. I tried sturm. It didn't
help. Then I changed a few control points and all the
artifacts disapeared.
Xuan Baldauf wrote:
> Hello,
> Attached:
> - The scene
> all: Pokal.v2.bug.png
> %.png: %.pov
>         /usr/lib/povray35/povray /usr/lib/povray35/povray.ini +I$< +O$@ +W840 +H630
+FN +SP8 +EP8 +V +L/usr/lib/povray35/include +UA +D +P
>    Pokal.v2.bug.pov       Type: POV-Ray scene file
(application/x-unknown-content-type-POV-Ray.Scene)
>                       Encoding: base64
Have Fun!
