POV-Ray : Newsgroups : povray.beta-test : No error message for array element nr. -1 Server Time
17 Feb 2026 18:56:46 EST (-0500)
  No error message for array element nr. -1 (Message 1 to 3 of 3)
Subject: No error message for array element nr. -1
Date: 8 May 2002 19:59:06
Message: <3CD9BB0E.61B2992@hotmail.com>
I just discovered that RC4 for Windows does not issue an
error message if one tries to access array element nr. -1
Here's the code I tried:
#declare A = array[1] { 0 }
// No error messages
#declare N = A[-1];
#declare A[-1] = 0;
// "Parse Error: Negative subscript"
#declare N = A[-2];
#declare A[-2] = 0;
If this is not old news, then can anyone please confirm this ?
Tor Olav
Subject: Re: No error message for array element nr. -1
Date: 9 May 2002 02:37:22
Message: <v66kdu0ou58og7rain2ur778mlhqgcd2bh@4ax.com>
On Thu, 09 May 2002 01:55:58 +0200, Tor Olav Kristensen
> #declare N = A[-1];
> #declare A[-1] = 0;
I can confirm however I wonder if it could be ... floating point accuracy.
What rounding is performed when float is converted to integer ? Truncation
towards zero ? Could it be that -1 is internally something like -0.99999999999
and after truncation it is valid value 0 ? If yes then possible fix is to
check sign of the float before conversion to int.
POV 3.5 RC4 icl on WinNT Sp 6 PII 233 with 128 MB
ABX
Date: 9 May 2002 04:32:03
Message: <3cda3403@news.povray.org>
The rounding method used requires a small bias to be added.  That is added
always.  It can of coure be fixed.
    Thorsten
e-mail: tho### [at] trfde
