POV-Ray : Newsgroups : povray.beta-test : Media broken? Server Time
30 Sep 2024 05:21:18 EDT (-0400)
  Media broken? (Message 1 to 7 of 7)
Subject: Media broken?
Date: 6 May 2002 12:43:16
Message: <3CD6B278.1994EC7F@gmx.de>
Build simple scene:
camera + two lightsources + media (without container)
You get:
Black image.
Or just use one fading lightsource, same result.
Anything one should consider when building conatiner-less media?
Using RC3, Win98, 512MB RAM, 1.4GHZ Athlon
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Media broken?
Date: 6 May 2002 13:08:46
Message: <3CD6B86E.F51FEFBA@gmx.de>
Hm. Noticed though that multiple spotlights work...
Tim Nikias wrote:
> Build simple scene:
> You get:
> Black image.
Tim Nikias
Date: 6 May 2002 14:59:11
Message: <slrnaddkf6.fhc.steve@zeropps.org.uk>
Have you tried rendering the example scenes, media1.pov and media2.pov
I get a partial image with media1 and a black image with media2 here
on my Linux system (as reported above).
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 6 May 2002 15:18:16
Message: <3CD6D6CC.9799E3F6@gmx.de>
Nope, but they are rendering fine.
I've got no clue, what the actual problem is.
Using something different than spotlights perhaps?
Tim Nikias
Date: 6 May 2002 17:26:31
Message: <3cd6f506@news.povray.org>
Tim Nikias <tim### [at] gmxde> wrote:
> Build simple scene:
> You get:
> Black image.
  Correct behaviour.
  Perhaps not the desired behaviour, but the expected one.
  The problem is that POV-Ray can't sample media along an infinitely long
ray. There's just no way it can do that. The ray must be finite in order
to be possible to sample. This means that sampling media is only possible
for rays that hit an object.
  Another way of being able to sample media is using spotlights because also
in this case the ray is not infinite (it is sampled only inside the spotlight
cone).
Date: 7 May 2002 00:38:24
Message: <3CD75A15.1095A02E@gmx.de>
Ah. Perhaps a note in the docs would be fitting?
> > Build simple scene:
> > You get:
> > Black image.
>   Correct behaviour.
> cone).
Tim Nikias
Date: 10 May 2002 04:20:06
Message: <9aohduc39rtqe2q8tl2qvnbre49rumfkv5@4ax.com>
On Tue, 07 May 2002 06:37:41 +0200, Tim Nikias <tim### [at] gmxde>
Look up the 'ratio' keyword under media.
Peter Popov ICQ : 15002700
