POV-Ray : Newsgroups : povray.beta-test : Media_attenuation bug? (Windows) Server Time
12 Jun 2026 22:51:19 EDT (-0400)
  Media_attenuation bug? (Windows) (Message 1 to 1 of 1)
Subject: Media_attenuation bug? (Windows)
Date: 26 Apr 2002 22:53:47
Message: <3CCA1221.30307@whoever.com>
I suspect this may be related to the previous posts about
media_attenuation, but since the poster didn't provide much detailed
info, and this is for the Windows version rather than Linux, I thought I
should post it separately.
When adding media_attenuation on to a point light source, I received the
following error message:
   The POV-Ray core rendering code caused an access violation exception.
   It is STRONGLY RECOMMENDED that you save your work and exit the
  program before attempting the render again.
   (Note that if internal structures have been damaged POV-Ray may crash
immediately after you click OK).
The following is a simple scene which recreates the error:
   location <0, 0, -1>
   look_at  <0, 0, 0>
   rotate <0, -10, 0>
   translate <1, 0, -3>
media {scattering {2, <.05, .05, .05> extinction .06}}
light_source {
   <3, 14, 20>
   rgb <1, 1, 1>
Changing the point light to a spotlight causes it to render without a
problem, by adding the following code to the light_source block:
   spotlight
   point_at <0, 3.5, 10>
   radius 20
   falloff 20
As far as I can tell from the documentation, while it seems to be
preferred to use a spotlight with media_attenuation, a point light
should work as well.
The sample scene renders without a problem in 3.1, with and without the
spotlight code.
Can anyone confirm?
Win98 SE; Athlon 1.4GHz; 512 MB DDR-ram; Pov-Ray for Windows 3.5 beta
Release Candidate 2
