POV-Ray : Newsgroups : povray.beta-test : #macros doesn't work in layered textures Server Time
12 Oct 2025 06:28:01 EDT (-0400)
  #macros doesn't work in layered textures (Message 1 to 4 of 4)
Subject: #macros doesn't work in layered textures
Date: 25 Apr 2002 01:05:12
Message: <3CC78E37.2030206@skynet.be>
//--- This #macro creates a simple color_map :
#macro BiColorMap (Coul1,Coul2,Seuil)
  color_map {
   [0 Coul1]
   [Seuil Coul1]
   [Seuil Coul2]
   [1 Coul2]
//--- I want to use it in a layered texture. This works as expected :
#declare T1 =  texture {
                   pigment {gradient x
                            BiColorMap (Clear,Gray50,.95)
                            scale 90}
#declare T2 =  texture {
                   pigment {gradient z
                            BiColorMap (Clear,Gray50,.9)
                            scale 90}
#declare T_Paves1 =
  texture {pigment {Gray80}}
  texture {T1}
  texture {T2}
//--- However, this causes an error :
#declare T_Paves2 =
  texture {pigment {gradient x BiColorMap (Clear,Gray50,.05) scale 90}}
  texture {pigment {gradient z BiColorMap (Clear,Gray50,.05) scale 90}}
// it tells me : "Parse Error: No matching } in 'pigment',
                   macro identifier found instead"
Fabien.
Subject: Re: #macros doesn't work in layered textures
Date: 25 Apr 2002 04:34:08
Message: <3cc7bf80@news.povray.org>
In article <3CC### [at] skynetbe> , Fabien Mosen
It works as designed.  No macros in layered textures.  The problem is that if
a macro would contain a declare the parser could no longer guess that two or
more texture identifiers are supposed to belong to the layered texture and not
some other declare.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 25 Apr 2002 04:45:42
Message: <3CC7C237.7C5A0751@gmx.de>
> some other declare.
It would probably be good to mention this in the docs, for example as an
Last updated 20 Apr. 2002 _____./\/^>_*_<^\/\.______
Date: 25 Apr 2002 09:21:24
Message: <3cc802d4@news.povray.org>
> some other declare.
  I propose a change in syntax for pov4. Layered textures should be inside
a clearly defined block, thus making it completely unambiguous to both the
parser and the user.
  It could be something as simple as:
texture
{ layered texture_map
  { (textures here)
