POV-Ray : Newsgroups : povray.beta-test : Round_Box #macro (in shapes.inc) and negative values Server Time
13 Jun 2026 00:24:36 EDT (-0400)
  Round_Box #macro (in shapes.inc) and negative values (Message 1 to 10 of 14)
Subject: Round_Box #macro (in shapes.inc) and negative values
Date: 21 Apr 2002 05:35:29
Message: <3CC2878E.9040708@skynet.be>
The scene below shows that the Round_Box_.. #macro in 'shapes.inc'
doesn't work well with negative values.  The elements of
the 'negative one' are misplaced.  I didn't take time yet to
see where's the problem, but I can say that the 'old' RoundedBox
#macro by John VanSickle works as expected.
Fabien.
#include "shapes.inc"
camera {location <15,50,-20> look_at <0,8,0> angle 30}
// bad
  object {
          Round_Box_Union (<-5,0,0>,<-10,15,-5>,.4)
          pigment {Red}
// good
  object {
          Round_Box_Union (<5,0,0>,<10,15,5>,.4)
          pigment {Yellow}
light_source {<1200,1600,1400> White*1}
light_source {<-1200,1600,-1400> White*1 shadowless}
Subject: Re: Round_Box #macro (in shapes.inc) and negative values
Date: 21 Apr 2002 05:56:27
Message: <3cc28ccb@news.povray.org>
But what do you expect to see
when using a negative value ?
Date: 21 Apr 2002 06:02:10
Message: <3cc28e22$1@news.povray.org>
> in 'shapes.inc' doesn't work well with negative values.
Thanks for the report.
I will fix this but it won't be included in RC2.
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated Apr 14)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Date: 21 Apr 2002 06:12:29
Message: <3CC2908C.FA85EEAA@gmx.de>
Rune, i already made a proposal for fixing this some time ago:
Subject: Problem in 'balcony.pov' and change suggestion for 'shapes.inc'
Date: Mon, 11 Mar 2002 11:03:02 +0100
Newsgroups: povray.pre-beta
news://news.povray.org/3C8C80D6.8EE78941@gmx.de
Last updated 20 Apr. 2002 _____./\/^>_*_<^\/\.______
Date: 21 Apr 2002 09:03:43
Message: <3CC2B859.8060005@skynet.be>
Thanks, but there is a small mistake (maybe things have changed
since ?).  The two first replaced lines must be :
    #local AA = <min(A.x, B.x), min(A.y, B.y), min(A.z, B.z)>
                + EdgeRadius;
    #local BB = <max(A.x, B.x), max(A.y, B.y), max(A.z, B.z)>
                - EdgeRadius;
(it's a matter of 'A' instead of 'AA')
Fabien.
Date: 21 Apr 2002 10:07:05
Message: <3cc2c789$1@news.povray.org>
I've been meaning to report this problem forever. The other problem that I
had noticed with Round_Box is that if the radius is exactly half the length
of one of the edges, you get "Parse Error: Degenerate cylinder, base point =
apex point". For example:
  Round_Box_Union (<5,0,0>, <10,15,5>, 2.5)
FWIW, here's my corrected version of the Round_Box macro in shapes.inc,
which fixes both problems.
// -----BEGIN-----
#macro Round_Box(A, B, EdgeRadius, UseMerge)
   #local AA = <min(A.x, B.x), min(A.y, B.y), min(A.z, B.z)> + EdgeRadius;
   #local BB = <max(A.x, B.x), max(A.y, B.y), max(A.z, B.z)> - EdgeRadius;
   #local LBF = AA;
   #local RBF = < BB.x, AA.y, AA.z>;
   #local RBB = < BB.x, AA.y, BB.z>;
   #local LBB = < AA.x, AA.y, BB.z>;
   #local LTF = < AA.x, BB.y, AA.z>;
   #local RTF = < BB.x, BB.y, AA.z>;
   #local RTB = BB;
   #local LTB = < AA.x, BB.y, BB.z>;
   #if(UseMerge)
      merge {
   #else
      union {
      sphere {LBF, EdgeRadius}
      sphere {RBF, EdgeRadius}
      sphere {RBB, EdgeRadius}
      sphere {LBB, EdgeRadius}
      sphere {LTF, EdgeRadius}
      sphere {RTF, EdgeRadius}
      sphere {RTB, EdgeRadius}
      sphere {LTB, EdgeRadius}
      #if (AA.x != BB.x)
         cylinder {LBF, RBF, EdgeRadius}
         cylinder {RBF, RBB, EdgeRadius}
         cylinder {RBB, LBB, EdgeRadius}
         cylinder {LBB, LBF, EdgeRadius}
      #if (AA.y != BB.y)
         cylinder {LBF, LTF, EdgeRadius}
         cylinder {RBF, RTF, EdgeRadius}
         cylinder {RBB, RTB, EdgeRadius}
         cylinder {LBB, LTB, EdgeRadius}
      #if (AA.z != BB.z)
         cylinder {LTF, RTF, EdgeRadius}
         cylinder {RTF, RTB, EdgeRadius}
         cylinder {RTB, LTB, EdgeRadius}
         cylinder {LTB, LTF, EdgeRadius}
      box {AA-EdgeRadius*x, BB+EdgeRadius*x}
      box {AA-EdgeRadius*y, BB+EdgeRadius*y}
      box {AA-EdgeRadius*z, BB+EdgeRadius*z}
// -----END-----
Anders
Date: 21 Apr 2002 12:12:35
Message: <3CC2E49D.6070609@skynet.be>
> apex point".
Maybe it's time to fix an inconsistency between primitives.
Here's how RC1 acts with zero-dimension volumes :
box {<10,10,10>,<10,10,10>}
  Rendering goes without a warning.
cylinder {<10,10,10>,<10,10,10>,1}
  Parsing stops with an error.
cone {<10,10,10>,1,<10,10,10>,2}
triangle {<10,10,10>,<10,10,10>,<10,10,10>}
  Rendering goes, but a warning is issued.
plane {0,0}
torus {0 0}
sphere {0,0}
Of course, these are very specific cases, but they can easily
happen in scenes with automatic object generation.  IMO, the
best thing that POV-Ray should do is render anyway, with a
warning, as it currently does with 'degenerate' triangles.
Fabien.
Date: 21 Apr 2002 12:41:05
Message: <t9qu9a.1rd.ln@wiemann.my-fqdn.de>
OK, I think.
The disc-cylinder can't be calculated, because the normal isn't known.
Same.
Doesn't behave like box does.
> plane {0,0}
Again the normal is unknown.
> torus {0 0}
Same as box.
> sphere {0,0}
Same as box.
The only inconsistency I see is the warning at the triangle. All
objects which generate an error can't be calculated due to the missing
normal.
Felix Wiemann
Date: 21 Apr 2002 13:08:12
Message: <3CC2F1A6.7000003@skynet.be>
Your explanations are mostly right, but belongs to POV-Ray's internal
cooking.  From a user's point of view, managing exceptions in #macros or
loops can be annoying.  All in all, I still think that simply removing
the 'degenerate' object is the best thing POV-Ray can do.
I guess that the degenerate triangle doesn't stop parsing because
it would be a PITA to manually remove one or two triangles from
a several thousand triangles externally generated mesh.  If an
external utility generated a net of cylinders, for example, to
represent a mesh as a wireframe, it would still be a PITA to
catch the degenerate ones.  That's why POV-Ray should remove
them with a simple warning, and not stop.
Fabien.
Date: 21 Apr 2002 13:12:15
Message: <3CC2F2ED.855B72C5@gmx.de>
> > apex point".
This could be caught in the macro, but if you really need it, you can
always write a wrapper macro for that yourself.  The problem would also be
what to do if the radius is even larger.
A warning for boxes with two identical points would be practicable, but i
don't see much use in that.  Cylinders with two identical points and
non-zero radius don't form a defined shape therefore the error is
inevitable (if radius is zero you could just render nothing, like the box,
but this is an even rarer situation).
If you have code automatically generating such objects you can always
catch those special situations yourself, just write a wrapper macro and
usage would not be much more difficult.
