POV-Ray : Newsgroups : povray.beta-test : Vanish/Ghost/Killer bug Server Time
12 Oct 2025 06:32:21 EDT (-0400)
  Vanish/Ghost/Killer bug (Message 1 to 6 of 6)
Subject: Vanish/Ghost/Killer bug
Date: 15 Apr 2002 14:58:58
Message: <3CBB230A.1E027FE2@gmx.de>
For those who have followed my recent bug-reports
about vanishing objects, focal-blur etc, I've posted
a minimum scene-file in beta-test.binaries.
I've tracked the bug down to a
vnormalize(<0,0,0>) used as a translation.
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Vanish/Ghost/Killer bug
Date: 15 Apr 2002 15:50:21
Message: <Xns91F1DE97AFC33seed7@povray.org>
From the doc:
vnormalize(A) Normalize vector A. Returns a unit length vector that is the
same direction as A. Formula is vnormalize(A)=A/vlength(A).
vnormalize(<0,0,0>) will not give a usefull result
Ingo
Date: 16 Apr 2002 00:29:33
Message: <3C92D851.CC58115B@gmx.de>
That's right, its in the docs. Though I think "not a useful result"
isn't something I'd expect to run loose on the entire
scene.
 Can't a default <0,1,0>, or better
(because we're dealing with a <0,0,0> vector) a
<0,0,0> be returned instead of some haywire?
Also, I didn't know that the reason for all this was
this vnormalize-issue, I thought it had something to
do with macros, because thats when it popped up
first with my Particle-System, and then with the
Gerbera.
ingo wrote:
> From the doc:
> Ingo
Tim Nikias
Date: 16 Apr 2002 02:04:27
Message: <Xns91F2529097941seed7@povray.org>
> scene.
I'll see what I can changein the text.
I would prefer an error. While making mesh generation macros I've been
bitten by this often. Investigation always showed that I did something
wrong in my code with the result of a <0,0,0> vector. It always took a
while to find the problems because POV-Ray just goes on parsing after a
vnormalize(<0,0,0>).
> Gerbera.
Shows the importance of reducing the scene as much as possible ;)
Ingo
Date: 16 Apr 2002 13:38:32
Message: <3CBC61A0.9217A1ED@gmx.de>
How about returning <0,0,0> as value AND giving
a warning-message? As long as that vector is needed
for translation, an error might be fine, but in certain
cases, in certain POV-SDL-Code, you might do
thousands of calculations with vnormalize(), but only
one (due to some random input) may result with
So, at least programming would be made easy.
Of course, the solution would be a macro, purposefully
named
VNormalize ( Vector ), which checks the length of the
vector (using vlength()), and if its !=0, you normalize,
otherwise, return a preffered value e.g. <0,0,0> or <0,1,0>.
That's what I'll probably do, because I believe this
bug is similiar to that strange pow() behaviour, and it may
be impossible and very inefficient to check for the
vnormalize(<0,0,0>) in POV itself (I think there a lot
of things which are done by POV because of inefficiency).
And regarding "reducing" the scene:
How about putting a section in the Docs which simply
state a list of "probably unexpected behaviour", which
cover pow(), vnormalize(), and I don't know what else
pops up? Just than one can check easily and fast.
ingo wrote something like:
Tim Nikias
Date: 17 Apr 2002 11:29:39
Message: <3cbd94e3@news.povray.org>
In article <Xns### [at] povrayorg> , ingo <ing### [at] homenl>
wrote:
> From the doc:
It will be an error in the next beta.
    Thorsten
e-mail: tho### [at] trfde
