Radiosity seems to be broken in RC1.
Try rendering 'radiosity/radiosity.pov' as it is and with an empty
radiosity block. With an empty block I get correct results, while the
standard settings lead to no radiosity effect (but the pretrace is done)
Photons generate a strange 'spotlight effect' (brightening around the
target objects), try 'lights/phot_met_glass.pov' for an example.
WinNT, RC1.icl, Athlon/K6
Last updated 14 Apr. 2002 _____./\/^>_*_<^\/\.______
"Christoph Hormann" <chr### [at] gmxde> wrote in message
news:3CBA7F49.166BA12A@gmx.de...
: Try rendering 'radiosity/radiosity.pov' as it is and with an empty
: radiosity block. With an empty block I get correct results, while the
: standard settings lead to no radiosity effect (but the pretrace is
done)
Confirmed. It's the recursion_limit. Comment it and radiosity works.
: Photons generate a strange 'spotlight effect' (brightening around the
: target objects), try 'lights/phot_met_glass.pov' for an example.
Confirmed.
WinXP, RC1.icl, Athlon/Tb
Ari-Matti
On Mon, 15 Apr 2002 09:20:41 +0200, Christoph Hormann <chr### [at] gmxde>
Could it be the same as in my observation ? Radiosity image in RC1 is darker
than in beta 16 with the same radiosity settings.
ABX
In article <3CBA7F49.166BA12A@gmx.de> , Christoph Hormann
No, the recursion limit is off by one (or maybe even two).
For photons the error is (nearly) the same but a bit more complex. In
general, increasing the recusion limits for each should work around the
problem (at least for radiosity).
Thorsten
e-mail: tho### [at] trfde
How do you change the recursion-limit for photons, when
there is no such option for it?
If you mean max_trace_level for photons, that one doesn't
work. You can set it way higher, or way lower, there's
no change.
> Thorsten
Tim Nikias
Email: Tim### [at] gmxde
It's off by two.
_____________
Kari Kivisalo
I was just about to post this! changing recursion limit by 2 does seem to correct the
problem with radiosity. Will this be changed
in the next RC? back to what it was or will this now become its normal behaviour.
Mick
the problem with radiosity. Will this be changed
As Kari said, it seems to be off by 2 so you have to use 3 to get
radiosity effect at all. Although Thorsten did not explicitly say i
suppose it will be fixed.
In article <3CBBC555.A0F28317@gmx.de> , Christoph Hormann
This part is already fixed already and will be in the next beta. As for the
photons problem it seems to be caused by introducing strict recusion level
checking for reflected rays. There was a bug there before and the problem is
a completely unitended side effect of the bugfix. Photons are surely going to
be fixed in one way or the other to work as they always did, too.
Thorsten
