POV-Ray : Newsgroups : povray.beta-test : uv_mapping in function crashes beta 13 Server Time
30 Sep 2024 11:20:27 EDT (-0400)
  uv_mapping in function crashes beta 13 (Message 1 to 10 of 15)
Subject: uv_mapping in function crashes beta 13
Date: 24 Mar 2002 06:17:47
Message: <3C9DB64B.3020006@web.de>
Whenn adding "uv_mapping" to a pigment in a function which is used for a
pigment in a texture it crashes beta13 (linux)
-> Speicherzugriffsfehler (english: segmentation fault?)
// ----- crashes -----
#declare f_png = function {
     uv_mapping      // problem here?
     image_map {png "plasma2.png"
       map_type 0
       interpolate 2
#declare T_tex =
       function { f_png (x,y,z).red }
box {
   <0, 0, 0> <1, 1, 1>
     T_tex
   translate <0, 0, 1>
// ----- works -----
       map_type 0
       interpolate 2
#declare T_tex =
       uv_mapping
box {
   <0, 0, 0> <1, 1, 1>
     T_tex
   translate <0, 0, 1>
Subject: Re: uv_mapping in function crashes beta 13
Date: 24 Mar 2002 09:18:57
Message: <3c9de051$1@news.povray.org>
Please try this again in beta 14 tomorrow.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 24 Mar 2002 15:10:47
Message: <3c9e32c6@news.povray.org>
  I really like the sound of that word. It really gives the impression that
something bad has happened... :)
  (No, I don't know any German.)
Date: 25 Mar 2002 13:08:43
Message: <3C9F681C.5060900@web.de>
Date: 25 Mar 2002 13:12:08
Message: <3C9F68EA.5040804@web.de>
Jep, works now!
Sebastian H.
Date: 25 Mar 2002 13:14:49
Message: <3c9f6919@news.povray.org>
In article <3c9e32c6@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
It is a more precise term than what segmentation fault also it means the same
:-)  In German nouns can be composed, so it is actually three words:
Speicher - zugriff(s) - fehler
memory   - access     - fault
    Thorsten
e-mail: tho### [at] trfde
Date: 25 Mar 2002 13:27:06
Message: <3C9F6C6C.2060409@web.de>
> Jep, works now!
> Sebastian H.
Oh no, didn't render full image.
It still crashes but later
and again with a
<drawverybigwithunderlinebecauseextrembadmessage>
SPEICHERZUGRIFFSFEHLER!!!!!!!
</drawverybigwithunderlinebecauseextrembadmessage>
Sebastian H.
Date: 26 Mar 2002 06:03:21
Message: <3ca05579@news.povray.org>
>    pigment {
>        map_type 0
>        interpolate 2
I am not sure what you are trying to do here with uv_mapping inside the
function.  I thought what you were seeing was related to another function
problem in beta 13 ("strange recursion error" thread in this group) and did
not look at your example, but it turns out that of course "uv_mapping" doesn't
even make sense inside functions.  I have fixed the parser and it will no
longer accept it in the next beta.
    Thorsten
Date: 26 Mar 2002 10:07:05
Message: <3CA08F0B.2000506@web.de>
>     Thorsten
This example was the shortened version of a try to make a uv_mapped
layered textures (with different finishes and bumps for each layer) for
a mesh2 object (which works now:-) ).
Since it was my very first try with functions some results were a bit
strange like the one I posted.
Like you said it doesn't make too much sense and I don't use this
construction at all.
But when I was playing around I was just wondering that this combination
completely crashes pov without any warning.
regards (from Bremen, where the sun is shining :-) )
Sebastian H.
Date: 26 Mar 2002 12:41:55
Message: <1ec1aucnb44fitsc6h6k6u378if1j6t5u9@4ax.com>
On Mon, 25 Mar 2002 19:14:47 +0100, "Thorsten Froehlich"
<tho### [at] trfde> wrote:
>In German nouns can be composed...
Pardon my spelling (I don't know German), but here's my favourite:
Love that language :)
Peter Popov ICQ : 15002700
