POV-Ray : Newsgroups : povray.beta-test : [Linux] shell-out substitutions Server Time
12 Oct 2025 14:44:28 EDT (-0400)
  [Linux] shell-out substitutions (Message 1 to 4 of 4)
Subject: [Linux] shell-out substitutions
Date: 1 Mar 2002 17:24:02
Message: <3C7FFEB2.22A1FDD3@inter.nl.net>
POV-Ray : 3.5.beta.11 Unix (.Linux.gcc)
Sytem : Linux 2.4.8-26mdk
RAM : 128Mb
When I render a .ini file like this:
Input_File_Name = reindert.pov
Output_File_Type = N
Output_File_Name = images/%s
Initial_Frame = 001
Final_Frame   = 100
Post_Scene_Command = convert images/%s*.png %s.mpg
then PovRay generates files like:
images/%s001.png
images/%s002.png
while I expect this:
images/reindert001.png
images/reindert002.png
Then, when I try to debug this, the following line gives a segmentation
fault:
Output_File_Name = images/%o %s %n
Regards, Theo
Subject: Re: [Linux] shell-out substitutions
Date: 11 Mar 2002 14:02:46
Message: <3C8CFFFB.1050708@gmx.net>
> Initial_Frame = 001
> Final_Frame   = 100
> images/%s001.png
> images/%s002.png
It isn't possible and doesn't make sense to use such substitutions in another
parameter than "..._Command"!
> fault:
Confirmed. It occurs when using more than one of the substitutions:
%o OK
%s OK
%n OK
%o%s NO
%o%n NO
%s%n NO
%o%x OK!
It seems to be a problem of these substitutions, because %o%x works
correctly (%x is no substitution).
Felix Wiemann
(Beta 12, SuSE Linux 7.3, P3 600, 128 MB)
Date: 23 Mar 2002 17:46:20
Message: <3c9d05bc@news.povray.org>
> another parameter than "..._Command"!
My goal was have one script (.ini) and change only the line with
Input_File_Name to render the next mpg. But the docs say substitution only
works in shell commands so let keep it as it is.
...hmm it make me wonder why the second error occurs...
Regards, Theo
Date: 23 Mar 2002 18:42:42
Message: <3c9d12f2$1@news.povray.org>
Try:
Anders
light_source{6#local D=#macro B(E)#macro A(D)#declare E=(E-#declare
C=mod(E D);C)/D;C#end#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(
C>2)}torus{1..2clipped_by{box{-2y}}rotate<1 0C>*90translate<D+1A(2)
*2+1#else}cylinder{0(C-v=1).2translate<D+C*A(2)A(4)#end-2 13>finish
{specular 1}pigment{rgb x}#end#end#end-8;1B(445000298)B(519053970)B
(483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)}
