POV-Ray : Newsgroups : povray.beta-test : Re: Colour of highlights Server Time
12 Oct 2025 22:32:51 EDT (-0400)
  Re: Colour of highlights (Message 1 to 3 of 3)
Subject: Re: Colour of highlights
Date: 16 Jan 2002 12:51:59
Message: <3C45BDBE.D1737EA1@gmx.de>
Hugo wrote:
> Hi,
> According to the docs, it is possible to control the colour of highlights by
> using the "metallic" keyword. Reflection and highlight should then be
> affected by the reflection <colour>. But this is not true. Specular / phong
> only takes on the pigment colour, where reflection takes on the colour of
> <colour>.. I would think, the most realistic thing is both to be affected in
> the same way.. (the best IMO is to have individual control of both but I'm
> afraid this will be considered a feature request...)
I think the docs are simply incorrect here.  'metallic' both in finish as
in reflection uses the pigment for coloring the highlights/reflection.
Date: 16 Jan 2002 13:36:49
Message: <3C45C7B4.5070802@skynet.be>
Hugo wrote:
> Hi,
Don't forget this : hightlights are just a quick simulation of
blurred reflection you see in real life.  If your object is
highly reflective (polished metal), don't use highlights,
and use "reflect_metallic".
Fabien.
Date: 16 Jan 2002 16:09:00
Message: <chrishuff-2B2711.16095916012002@netplex.aussie.org>
In article <3C4### [at] skynetbe>,
"reflect_metallic" is from MegaPOV, for POV 3.5 put "metallic" in the
reflection {} block.
