POV-Ray : Newsgroups : povray.beta-test : Bug with transform syntax Server Time
14 Mar 2026 11:43:15 EDT (-0400)
  Bug with transform syntax (Message 1 to 2 of 2)
Subject: Bug with transform syntax
Date: 27 Dec 2001 19:30:50
Message: <chrishuff-5FC1B7.19310427122001@netplex.aussie.org>
The "transform {}" syntax seems not to work within textures...
This:
   texture_map {
      #local J = 0;
      #while(J < Samples)
         [J/(Samples - 1) Texture transform {rotate y*Amt*pow(J/(Samples
- 1), Exp)}]
         #local J = J + 1;
will give a parse error "Expected 'transform identifier', { found
instead", but this works:
   texture_map {
      #local J = 0;
      #while(J < Samples)
         #local Trans = transform {rotate y*Amt*pow(J/(Samples - 1),
Exp)}
         [J/(Samples - 1) Texture transform Trans]
         #local J = J + 1;
(I will post a test scene if necessary)
I have only noticed it happening in texture_maps, but I think I saw
someone else mention it happening with pigments, so there are probably
other cases where it happens.
Subject: Re: Bug with transform syntax
Date: 30 Dec 2001 15:06:53
Message: <3C2F73B8.C1E3C60D@gmx.de>
I mentioned this in:
Subject: transform syntax
Date: Sun, 02 Dec 2001 10:02:19 +0100
Newsgroups: povray.beta-test
