POV-Ray : Newsgroups : povray.beta-test : bug in sphere_sweep for removing parts of an object Server Time
2 Nov 2024 07:24:15 EDT (-0400)
  bug in sphere_sweep for removing parts of an object (Message 1 to 6 of 6)
Subject: bug in sphere_sweep for removing parts of an object
Date: 14 Dec 2001 15:09:24
Message: <3C1A5D47.EA38F6E5@amc.uva.nl>
I am not entirely sure if this has been reported before.
I used  povray v3.5b8 on a 750MHz PIII, windows 98
When using sphere_sweep to generate a hollow tube there are
some problems in rendering the inside of the tube.
Strange bands of discontinuous normals seem to appear in areas where
the spheres make a bend.
Below is a 'small' example that shows the problem.
Second point is that I used a parameterization for the sizes
of the spheres that depended on the clock to generate an animation.
It was a rather complex formula. I now use a different method where
I generate an different include file for every frame. The reason
is that this seems to be much faster. Apparently the formula
is computed for every pixel in stead of ones per frame. I
think some caching may improve the speed of rendering.
	Andrel
#version 3.5;
global_settings {
  assumed_gamma 1.0
  location  <0.0, 0.5, -4.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-0, 5, -10>
plane {
  y, -1
  pigment { color rgb <0.3,0.7,0.3> }
intersection{
sphere_sweep {
 catmull_rom_spline
 11,
 <-0.785398,0.000000,0.000000>,0.684887,
 <-0.392699,0.000000,0.000000>,0.747715,
 <0.000000,0.000000,0.000000>,0.779126,
 <0.342020,0.060307,0.000000>,0.792240,
 <0.642788,0.233956,0.000000>,0.797142,
 <0.866025,0.500000,0.000000>,0.798889,
 <0.984808,0.826352,0.000000>,0.799517,
 <0.984808,1.173648,0.000000>,0.799752,
 <0.866025,1.500000,0.000000>,0.799843,
 <0.642788,1.766044,0.000000>,0.799875,
 <0.342020,1.939693,0.000000>,0.799871
}// end sphere_sweep
sphere_sweep {
 catmull_rom_spline
 11,
 <-0.785398,0.000000,0.000000>,0.479132,
 <-0.392699,0.000000,0.000000>,0.545101,
 <0.000000,0.000000,0.000000>,0.578083,
 <0.342020,0.060307,0.000000>,0.591852,
 <0.642788,0.233956,0.000000>,0.596999,
 <0.866025,0.500000,0.000000>,0.598833,
 <0.984808,0.826352,0.000000>,0.599492,
 <0.984808,1.173648,0.000000>,0.599739,
 <0.866025,1.500000,0.000000>,0.599835,
 <0.642788,1.766044,0.000000>,0.599868,
 <0.342020,1.939693,0.000000>,0.599865
inverse }// end sphere_sweep
box{<-3.141593,-1,-.15><2,3,1>}
bounded_by{box{<-3.141593,-1,-.15><2.284808,3.3,1>}}
  translate x*2.5+y*-3+z*-3
  scale .5
  rotate x*45+y*40
  pigment { color rgb <1,0.2,0.0> }
  finish{specular .3}
}// end difference
Subject: Re: bug in sphere_sweep for removing parts of an object
Date: 15 Dec 2001 02:37:00
Message: <sQycrBAaQrG8EwNH@econym.demon.co.uk>
I confirm this. The effect seems to happen with any inverse
sphere_sweep, or any difference {something, sphere_sweep}. The normals
in the inverse sphere_sweep are not the inverse of the normals of the
sphere_sweep.
I can't reproduce that with simple formulae that use the clock.
You're not using functions by any chance are you?
Mike Williams
Gentleman of Leisure
Date: 15 Dec 2001 05:24:49
Message: <3c1b24f1@news.povray.org>
In article <sQy### [at] econymdemoncouk> , Mike Williams
> sphere_sweep.
This suggests the normals are not inverted (at all?) because a difference is
simply an intersection with the inverted object and thus the cause of both
problems is identical.
    Thorsten
e-mail: tho### [at] trfde
Date: 15 Dec 2001 08:25:29
Message: <3C1B5008.7EBEAEDA@amc.uva.nl>
I meant that I used things like
sphere_sweep {
 catmull_rom_spline
 11,
 <-0.785398,0.000000,0.000000>,1-(exp(-(2-sin((clock)*2*pi))*4)*25),
(or worse) does that count as using functions?
	Andrel
Date: 15 Dec 2001 09:15:31
Message: <WeTy4NAfp1G8EwLx@econym.demon.co.uk>
>sphere_sweep {
> catmull_rom_spline
> 11,
No. All that stuff gets evaluated at parse time. It doesn't affect the
speed of the rendering.
The various frames take different amounts of time to render, but only
because the object varies in size. In particular, on my machine, the
time to render a frame with clock=0 containing lots of things like
renders in exactly the same time as one containing things like
  <-0.785398,0.000000,0>,0.991613,
Mike Williams
Date: 15 Dec 2001 10:10:14
Message: <3C1B68A9.6743B7FF@amc.uva.nl>
> >sphere_sweep {
> > catmull_rom_spline
> > 11,
I would expect so.
mmm, I will try to recreate what I did. Consider this solved (category:
not a bug after all) I will repost if I can recreate the problem and
have some measurements. Thanks for looking into it.
	Andrel
