POV-Ray : Newsgroups : povray.beta-test : Disappearing Large Sphere Bug in beta 8 Server Time
31 Mar 2026 11:37:52 EDT (-0400)
  Disappearing Large Sphere Bug in beta 8 (Message 1 to 10 of 10)
Subject: Disappearing Large Sphere Bug in beta 8
Date: 1 Dec 2001 17:53:47
Message: <3C095E20.C3FF6972@lineone.net>
I've discovered a problem with very large spheres seeming to vanish
above a certain size. This fisrt showed itself when I was trying
to use randomly placed spheres to create a starfield: when I moved
the spheres further away from the camera (and made them larger) they
vanished.
I've seen this problem under Win 98 using POVRay 3.5 beta 8. I've
created
a small scene file and .ini file to demonstrate the problem. This
creates
an animation of a radius 1 sphere being scaled by values between 0 and
4,000,000 (the camera's at the origin, and the sphere is a few units
away). The sphere /should/ stay the same size, but at around
scale 2,800,000 it shrinks away, and vanishes.
This problem only seems to occur with evenly scaled spheres - I've tried
it with boxes and unevenly scaled spheres, and they're OK.
I'll post the .pov and .ini files to povray.beta-test.binaries
Thanks,
Alun.
Subject: Re: Disappearing Large Sphere Bug in beta 8
Date: 2 Dec 2001 07:27:54
Message: <3c0a1e4a@news.povray.org>
In article <3C095E20.C3FF6972@lineone.net> , James Hansen
> vanished.
Not a bug.  Your sphere simply grows out of the the space POV-Ray considers
for intersection.  It is similar to:
<http://www.students.tut.fi/~warp/povVFAQ/misconceptions.html#simulatingsun>
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 2 Dec 2001 07:49:50
Message: <3c0a236e@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: Not a bug.  Your sphere simply grows out of the the space POV-Ray considers
: for intersection.
  Do you think this limit should be expanded, or are there good reasons to
keep it like it is currently?
Date: 2 Dec 2001 08:04:36
Message: <3c0a26e4@news.povray.org>
In article <3c0a236e@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
The current limit is 10^7 by default.  I think it is reasonable if you
consider that to find the distance you end up with more than 10^14 and have
to take the sqare root.  I think more could be slightly out of the necessary
precision for root finders under some conditions.
    Thorsten
e-mail: tho### [at] trfde
Date: 2 Dec 2001 08:39:25
Message: <3c0a2f0d@news.povray.org>
: The current limit is 10^7 by default.  I think it is reasonable if you
: consider that to find the distance you end up with more than 10^14 and have
: to take the sqare root.  I think more could be slightly out of the necessary
: precision for root finders under some conditions.
  Perhaps the documentation should mention these kind of limitations so that
people could be aware of them.
Date: 2 Dec 2001 14:59:01
Message: <Xns916BD577CA12Fseed7@povray.org>
>   limitations so that
What more limitations are there, what is their value and are they
system dependent?
Ingo
Date: 2 Dec 2001 16:21:49
Message: <3c0a9b6d$1@news.povray.org>
In article <Xns### [at] povrayorg> , ingo <ing### [at] homenl>
> system dependent?
They depend on the system and are subject to be improved without notice.  It
might be a good idea to have absolute numbers for this in the docs...
    Thorsten
Date: 2 Dec 2001 16:23:10
Message: <3c0a9bbe@news.povray.org>
Well, every primitive probably has it's own limit (cone is extremely sturdy,
as I recall) and it might vary from system to system too but I wouldn't know
if so.
If you weren't looking to do anything but to document a generalization you
could just say very large or very small numbers lead to difficulties in
visiblity or appearance.
BTW, I think light_sources have or had a distance limitation too.  Too low
color values for lights isn't limited anymore though, I think, thanks to
Nathan Kopp.
Extreme camera 'angle' or 'direction' (and distance?) also has an effect on
things.
text{ttf"arial","bob h",.1,0pigment{rgb 9}translate<-1,-.2,3>}
"ingo" <ing### [at] homenl> wrote in message
news:Xns### [at] povrayorg...
> >   limitations so that people could be aware of them.
> system dependent?
Date: 2 Dec 2001 17:31:27
Message: <3c0aabbf@news.povray.org>
: They depend on the system and are subject to be improved without notice.  It
: might be a good idea to have absolute numbers for this in the docs...
  Then at least a note that a limitation exists, so people will not be
surprised if they find it.
Date: 2 Dec 2001 17:43:16
Message: <3c0aae84@news.povray.org>
In article <3c0aabbf@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Yes, of course, just no absolute numbers.
