POV-Ray : Newsgroups : povray.beta-test : Field rendering status Server Time
7 Mar 2026 03:20:42 EST (-0500)
  Field rendering status (Message 1 to 10 of 15)
Subject: Field rendering status
Date: 27 Oct 2001 14:30:26
Message: <3BDAFCBA.3E20163C@geocities.com>
Soo.....
After looking into it again, I think it's clear that POV-Ray is doing
things a little bit halfway compared to other 3D & video packages.
However, my off-hand guess is that it would take a bit of work to get
things to save two fields per one file. :-(
So, does this then chang it from a bug to "works as designed", and thus
changing it becomes a feature-request instead of a bug-fix?
If it's WAD, I could probably write up a new bit for the docs to explain
it better.
Jon A. Cruz
http://www.geocities.com/joncruz/action.html
Subject: Re: Field rendering status
Date: 27 Oct 2001 15:07:43
Message: <3bdb05ff@news.povray.org>
In article <3BDAFCBA.3E20163C@geocities.com> , "Jon A. Cruz"
> it better.
Well, POV-Ray could automatically use half the clock step size and thus
generate as many frames as expected (twice as many as it does not)...
    Thorsten
e-mail: tho### [at] trfde
Date: 27 Oct 2001 15:28:48
Message: <3bdb0af0$1@news.povray.org>
I imagine it would be very hard to fix this, because POV would have to parse
what is internally two separate scenes for a single frame.
Someone needs to write a program that will take the output images and
combine them as necessary. =)
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
"Jon A. Cruz" <jon### [at] geocitiescom> wrote in message
news:3BDAFCBA.3E20163C@geocities.com...
> Soo.....
> it better.
> Jon A. Cruz
Date: 29 Oct 2001 05:44:08
Message: <3BDD3334.DEFED0A4@atosorigin.com>
"Jon A. Cruz" wrote:
> Soo.....
Two fields per file is a BAD idea. Where is the gain when one would only
want to rerender the odd fields
(on one computer, and the even fields on another).
When doing fields thing, at 25fps, I believe it's normal to have to provide
50 files per second. The content of each file may have to be adapted for
the current animation softwares, but that's another story.
Date: 29 Oct 2001 13:19:14
Message: <3bdd9da2$1@news.povray.org>
-Hail
  You say it is a bad idea, that claerly shows that you never did any work
involving video. I tried once to use pov for my multimedia projects and I
almost lost my job because I was trying to get the field rendering to work
proprly in the end I scrapped this idea because I had no choice, then on my
spare time I figured out the way to do this right, it involved many tests
with many types of footage. The conclusion I came to is clear and I dont see
why you could be against this. Name one piece of software or hardware that
will accept this format.
Date: 29 Oct 2001 13:27:26
Message: <3bdd9f8e@news.povray.org>
In article <3bdd9da2$1@news.povray.org> , "Vampyrium"
QuickTime and all the DVD tools Apple sells (which have more than 50% DVD
authoring market share), Adobe Premiere, ...
    Thorsten
Date: 29 Oct 2001 13:43:47
Message: <3bdda363@news.povray.org>
-Hail
  So, this is an apple thing. If you check out Adobe Premiere (PC version)
you will find otherwise. Anyhow this topic should have been resolved by now,
since it isnt lets come to a final solution that remains permanent as this
is taking up useful time from both sides.
Date: 29 Oct 2001 14:15:08
Message: <3bddaabc@news.povray.org>
In article <3bdda363@news.povray.org> , "Vampyrium" <cyb### [at] hotmailcom>
No, it isn't.  As there should be no difference between the Premiere
versions on Macs and PCs.  Also the other remaining DVD authoring software
company Sonic/Daikin (they recently merged) seems to supports such import
with their products (I don't know anybody who has access to those).  So I
really don't see a problem other than that POV-Ray doesn't adjust the clock
frequency to create twice as many images when field rendering is used - and
that is a really simple to "fix" problem.
If you have a problem importing the format in Adobe Premiere I can try to
find someone who has the PC version and send you detailed instructions for
PCs if you think the PC version is different...
    Thorsten
Date: 29 Oct 2001 14:43:52
Message: <3bddb178@news.povray.org>
I have the PC version of Adobe Premiere, and although I haven't used it
extensively enough to say that this is or is not possible, I would
appreciate instructions on how POV's feild rendering could be imported into
it. As far as I can tell, from the way it uses feild rendering *itself* with
transitions and things, the two-feilds-in-one-frame method (the one POV
*doesn't* do) is the necessary one.
- Slime
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3bddaabc@news.povray.org...
version)
clock
and
>     Thorsten
Date: 29 Oct 2001 15:48:10
Message: <3bddc08a@news.povray.org>
I figured this out. First import the file (or list of still frames) through
File -> Import. Then place the clip onto the timeline. Right click on the
clip and go to Video Options -> Field Options. Select "Interlace consecutive
frames."
Then choose the Rate Stretch Tool (next to the razor blade tool) and shrink
the clip to half it's length.
That should give you what you want.
- Slime
"Slime" <noo### [at] hotmailcom> wrote in message
news:3bddb178@news.povray.org...
into
with
> - Slime
> version)
software
import
I
> clock
> and
to
for
> >     Thorsten
