POV-Ray : Newsgroups : povray.beta-test : Tiny function-script that crashes v3.5.beta.6.icl.win32 Server Time
13 Oct 2025 14:04:02 EDT (-0400)
  Tiny function-script that crashes v3.5.beta.6.icl.win32 (Message 1 to 10 of 11)
Subject: Tiny function-script that crashes v3.5.beta.6.icl.win32
Date: 22 Oct 2001 17:13:12
Message: <3BD48BAD.EB974804@hotmail.com>
Here it is:
(Crashes in Win98 on my 100 MHz Pentium.)
union {
  sphere { y, 1 }
//  sphere { z, 1 }                  // Uncomment these lines
//  pigment { color rgb <1, 1, 1,> } // to get rid of warnings
#local Fn = function(x) { x }
#debug ""
#declare Fn = function(x) { x }
The error message in window titled "Pvengine":
"This program has performed an illegal operation
and will be shut down."
The editor does not disappear before on clicks
on the "Close" button. (It is functioning OK
until one does.)
The details:
PVENGINE caused an invalid page fault in
module PVENGINE.EXE at 015f:0042bc1d.
Registers:
EAX=00000000 CS=015f EIP=0042bc1d EFLGS=00010246
EBX=00000000 SS=0167 ESP=0728f1f8 EBP=00000000
ECX=0000003a DS=0167 ESI=00cab884 FS=457f
EDX=00000031 ES=0167 EDI=00000031 GS=0000
Bytes at CS:EIP:
8a 37 8b cf 84 f6 74 08 41 40 8a 11 84 d2 75 f8
Stack dump:
00cab458 006914e0 00cab360 00000000 00000000 00cab884 00000039 0047a00a
00000001 00492de8 0061b690 0068eae0 00ca48f0 0000066b 00000000 00000000
Subject: Re: Tiny function-script that crashes v3.5.beta.6.icl.win32
Date: 22 Oct 2001 17:29:49
Message: <3BD48FCD.F738ECDD@gmx.de>
Tor Olav Kristensen wrote:
> Here it is:
> union {
>   sphere { y, 1 }
> #debug ""
I think that's the same bug that made the waveform sample in the insert
menu crash.  An '#undef Fn' between should help.
Date: 22 Oct 2001 17:35:44
Message: <3BD490F4.B514D710@hotmail.com>
I'm not able to find that waveform sample.
Where is it ?
And where can I find the bug report for this ?
Tor Olav
Date: 22 Oct 2001 17:51:06
Message: <3bd494ca@news.povray.org>
In article <3BD490F4.B514D710@hotmail.com> , Tor Olav Kristensen
> Where is it ?
It happens to be the same as:
> Crash after constant function
> http://news.povray.org/kc3hqtkgj93f82rpkj6puvlj8f5cs7nk0q@4ax.com
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 22 Oct 2001 18:01:40
Message: <3BD49742.9D2BF514@gmx.de>
> Where is it ?
In the insert menu: Pattern-Texture Attributes/waveform attribute
source file: Attributes.pov
In fact that bug already occurred in beta 5:
Subject: Re: crashes when rendering insert menu
Date: Mon, 08 Oct 2001 09:08:47 +0200
Newsgroups: povray.beta-test
Date: 22 Oct 2001 20:28:06
Message: <3BD4B95A.772FA9D7@hotmail.com>
> > Where is it ?
> From: Christoph Hormann <chr### [at] gmxde>
Hmmm...
Thorsten says that this bug is the same as one
In that post he mentioned "POV3.5b2".
Subject: "number of parameters in functions"
Does this mean that your post, ABX's and mine is
all about the same bug ?
And that it appeared for the first time in beta 2 ?
Tor Olav
Date: 22 Oct 2001 20:30:54
Message: <3BD4BA05.3BAD37E4@hotmail.com>
> > Where is it ?
Found it.
So it didn't crash because of the constant function,
but because of the redeclaration of the function ?
If so, then the "name" of the bug is a bit misleading,
isn't it ?
Tor Olav
Date: 23 Oct 2001 03:12:11
Message: <3bd5184b$1@news.povray.org>
In article <3BD4BA05.3BAD37E4@hotmail.com> , Tor Olav Kristensen
Yes, after some analysis this seems to be the case.
    Thorsten
e-mail: tho### [at] trfde
Date: 23 Oct 2001 03:24:18
Message: <ui6attopuncrllrq9uk5gvp4d0j34436ia@4ax.com>
On Mon, 22 Oct 2001 23:51:03 +0200, "Thorsten Froehlich"
>    Thorsten
I'm the author of this post but I tested this bug with beta 6 and it
works fine on the same machine (but I had to add three args within
last line)
ABX
Date: 23 Oct 2001 03:55:21
Message: <3BD52269.9B603A77@gmx.de>
> Hmmm...
Seems to be.  If this is the case it's also the same bug that behaved
differently with the Intel/MSVC compile and on the different machines.
