> When I try to find that according to the
> formula mentioned in that section, "direction_length = 0.5 * right_length
> tan(angle / 2) where right_length is the length of the right vector", I
come
> up with about 'direction 0.56' which is just more than half of what it
ought
> to be.
Really? I come up with 1.00722346241. The exact value for angle is 2 atan
(2/3), or about 67.38013502.
Anders
Speaking of this, in doc sections 6.4.1.5.1 and 6.4.1.5.2, it says that the
default value for right is <1.33, 0, 0>. Shouldn't this be <4/3, 0, 0>, as
stated in section 6.4.1.5?
"Anders K." <and### [at] f2s com> wrote in message
news:3bcc5632$1@news.povray.org...
Hmm, AFAIK 4/3 cannot be expressed accurately in either dec. or bin. - both
therefore look like approximations - or did you just mean for consistency's
sake?
> sake?
To clarify things, the default right vector is 1.33*x so this is what the
docs should say too IMO.
Christoph Hormann <chr### [at] gmx de>
news:3bcc53ab$1@news.povray.org...
right_length
> come
> ought
> > to be.
Right. Well, apparently tan 67/2 isn't a good way to go about calculating
it. I left off the parentheses in my quick attempt :-)
Bob H.
If the default right vector is really 1.33*x and not 4/3*x then that is a
program bug (or design flaw, or whatever), since the aspect ratio of the
images it normally produces is *exactly* 4 to 3 and not 1.33 to 1.
Of course, I realize that 1.33 is an "approximation" to 4/3, but IMO it's a
pretty bad approximation, especially for large images. And in this case
there is no need to approximate at all (other than the internal floating
point rounding error, which is going to be much, much less than .01). So I
think that both the program and the docs should use 4/3.
Anders
> what the docs should say too IMO.
If this value comes from the source, I'll match the documentation.
Ingo
Pov-Ray : http://members.home.nl/seed7/
It does (in Povray 3.1)
ingo <ing### [at] home nl> wrote:
: If this value comes from the source, I'll match the documentation.
Also I think that it's the source which should be fixed (to 4.0/3.0).
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
> 4.0/3.0).
Could The Team take a position on this so I can make the appropriate
changes?
Ingo
