POV-Ray : Newsgroups : povray.beta-test : Crash - gaussianblob.pov Server Time
28 Apr 2026 08:47:39 EDT (-0400)
  Crash - gaussianblob.pov (Message 11 to 20 of 20)
Subject: Re: Crash - gaussianblob.pov
Date: 11 Oct 2001 19:21:13
Message: <3bc62968@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: This is what I meant.  It makes sense, but the numbers are almost never
: useful after the fact.
  I think that the numbers are really meaningful only if you are coding
in assembler (because then the numbers are exactly what you have written,
ie. directly your code in machine code, which can be easily disassembled).
  If you are making a C++ program, the numbers don't really tell you
anything (unless you know *really, really* well what does the compiler
spit out from your code).
  A compiler with a debugger can, however, use this error window to jump
directly to the source code line where the crash ocurred (if the program
has debug information linked in).
Date: 12 Oct 2001 02:17:21
Message: <3bc68af1@news.povray.org>
"Thorsten" <tho### [at] ewetelnet> wrote in message
news:3BC5B0DA.5404C9E5@ewetel.net...
> Or is there somebody out there, using an English windows version, and
having the
> same problems with gaussianblob.pov ?
Having problems, don't know if they're the same.
5 min into parsing pov crashed with the following error:
"The exception unknown software exception (0xc00000fd) occurred in the
application at
location 0x004292a6. Click OK to Close, Cancel  to Debug"
Pov-ray 3.5 Beta 6 Pentium 300 128MB Ram, Windows 2000
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.          Babylon 5 *
* Just think of me as the storm before the calm     Magic: The Gathering*
Date: 12 Oct 2001 10:30:58
Message: <3bc6fea2@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
> On Thu, 11 Oct 2001 16:46:51 +0200, Thorsten wrote:
> >But I think the most important information in the German message were the
values
> You might think so, but probably not.  I don't think I've ever gotten what
> could be called useful information from anything in that message except
> maybe the CS:EIP.
Another fond illusion shattered - you mean those numbers mean no more to you
programmers than they do to us muggles? Someone should inform snopes2.com...
Date: 12 Oct 2001 11:19:38
Message: <slrn9se2gc.fov.ron.parker@fwi.com>
>values
>> maybe the CS:EIP.
Oh, they mean something.  It's just that what they mean isn't terribly
useful most of the time.  Some of them are less useful than they could be,
granted, but even the ones that could be useful are practically useless
unless you happened to generate a detailed map file when you built the
code, and even then they only become marginally useful because you can't
see how the system got there (the "stack dump" is poorly formatted and
far too short, so you can't even get a decent stack trace.)
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 14 Oct 2001 20:41:17
Message: <slrn9skc5e.ip.ron.parker@fwi.com>
On Thu, 11 Oct 2001 09:47:10 +0200, Thorsten wrote:
>Hello :-))
>scenes/advanced/gaussianblob.pov crashed on my PII-233,96MB,Windows95.
Oddly enough, I can't duplicate this on my dev build (though I'd like to
point out how horribly long it takes to parse this scene on a K6/2-350.)
Are you absolutely sure you were using beta 6 when this happened?
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 14 Oct 2001 23:14:33
Message: <3bca5499@news.povray.org>
I can confirm this. PIII/933, 256 MB RAM, Win98SE. Exactly 3 minutes into
Parsing ... I get the following error message. Funny thing is, the timer
keeps ticking until I close the error dialog.
D.
PVENGINE caused a stack fault in module PVENGINE.EXE at 0187:004292a6.
Registers:
EAX=00000000 CS=0187 EIP=004292a6 EFLGS=00010246
EBX=0689e7f8 SS=018f ESP=065c1fd0 EBP=06b992c8
ECX=065c2140 DS=018f ESI=00cb02a8 FS=57d7
EDX=005d4310 ES=018f EDI=00000000 GS=0000
Bytes at CS:EIP:
89 2c 24 89 5c 24 04 89 74 24 08 ff 12 85 c0 74
Stack dump:
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
> >Hello :-))
x}rotate
1rotate 60
Parker
Date: 15 Oct 2001 02:50:29
Message: <3BCA867C.CDEF88C0@ewetel.net>
Hello Ron :-))
Ron Parker:
It crashed after some minutes. If you think the time might be relevant, I'll try to
find out the exact time.
Yes, I am.
Greetings :-))
Thorsten
Date: 15 Oct 2001 08:59:10
Message: <3BCADCDF.E7DFF51C@ewetel.net>
Hello :-))
Latest news:
gaussianblob.pov works for me with this change
#declare CompNum=6946;
I've also tried some other values for CompNum smaller than 6946 with no problems :-))
But it keeps crashing for
#declare CompNum=6947;
or higher values for CompNum :-((
By adding some #debugs (code below) I found out these things:
The crash always happens for N=6946.
It seems to be no rand() thing, because I've used various seed()s without any
influence
on the results.
The problem seems to be caused by the line
#declare Tracey=trace(Ally,Test+100*y,-y,Norm);
because these were the last lines of debug information:
N=6946
Test ok.
This is the part of gaussianblob.pov with some additional #debugs. To keep this
message
short, I've removed the original comments...
#while(N<CompNum)
  #debug concat("N=",str(N,4,0),"\n")
  #declare Test=<Gauss(S),0,Gauss(S)>;
  #debug "Test ok.\n"
  #debug "Tracey ok.\n"
  #if (Norm.x = 0 & Norm.y = 0 & Norm.z = 0)
    #declare Posy[N]=Test;
  #else
    #declare Posy[N]=Tracey+Norm*CompRadius;
  #debug "if ok.\n"
  #declare Ally=
  union {object {Ally}
    sphere {Posy[N], CompRadius}
  #debug "Ally ok.\n"
  #declare N=N+1;
Greetings :-))
Thorsten
Date: 17 Oct 2001 11:28:33
Message: <3bcda3a1@news.povray.org>
This is a stack issue which has been rectified for the next beta.
-- Chris
Date: 30 Oct 2001 06:17:16
Message: <3BDE8B23.2F1D2B3D@ewetel.net>
Hello Chris :-))
Chris Cason:
The gaussianblob causes no problems anymore...
BTW: It works with both beta7 compiles.
Thank you. Greetings :-))
Thorsten
