POV-Ray : Newsgroups : povray.beta-test : Increased memory use in 3.5 Server Time
30 Jan 2026 08:41:29 EST (-0500)
  Increased memory use in 3.5 (Message 1 to 6 of 6)
Subject: Increased memory use in 3.5
Date: 2 Oct 2001 15:28:21
Message: <3BBA15ED.66A08285@ibras.dk>
I don't know if this is a bug, a feature or just me overlooking a change
in default setting, but I have seen that the same scene uses a lot more
memory when rendered with 3.5b4 than with 3.1g. Have anybody else
noticed that, too?
The scene I'm working on currently uses 167MB in 3.1 and 339MB in 3.5. I
have tried a couple of other scenes, and the increase in peak memory use
is between 1.5x and 2x.
Windows NT4 SP6, PIII and Athlon, v. 3.5b4
/Ib
Subject: Re: Increased memory use in 3.5
Date: 2 Oct 2001 16:36:07
Message: <3bba2537@news.povray.org>
As Thorsten Froehlich advised, I will describe some experiences with memory
usage of different Pov-Ray derivatives.
I took an older maketree scene and put the resultant tree in a while loop
which creates 9 trees. Trunk and twig texture (normal, but none of the
standard textures) was asigned seperately to every cone and sphere
(dotexture = true).
Peak memory usage was 148 MB with v. 3.1g and 579 MB with v. 3.5b4.
When the same texture was asigned to the tree as an entity (dotexture =
false),
peak memory usage was 121 MB with v. 3.1g and 182 MB with v. 3.5b4.
Why is there such a great difference in memory usage wihin 3.1g and 3.5?
Changes in texture management?
memory when rendering the same scene as v. 3.5.
Norbert Kern
Date: 2 Oct 2001 18:18:49
Message: <3bba3d49@news.povray.org>
I don't know what is the exact answer, but let me throw a wild guess:
  The structs containing object information have grown, ie. they have more
items inside them. Some new features require some extra data in objects and
other similar items.
  This of course means that each object takes more memory and this can be
seen when creating lots of them.
  If this is the reason, the only solution I can think of is to try to look
if the object structs could be optimized for size (eg. use 'union' instead
of 'struct' wherever possible, merge two variables into one if possible, and
so on).
Date: 3 Oct 2001 11:47:43
Message: <3bbb331f$1@news.povray.org>
In article <3bba3d49@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Not that much, especially compared to MegaPOV.
    thorsten
e-mail: tho### [at] trfde
Date: 3 Oct 2001 12:32:36
Message: <slrn9rmfd6.jp8.ron.parker@fwi.com>
I don't see it turned on in the Windows config.h I have, but is it possible
that the betas have memory tracking enabled?
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 3 Oct 2001 13:01:58
Message: <3bbb4486@news.povray.org>
In article <slr### [at] fwicom> , ron### [at] povrayorg (Ron
The Mac one has, but I don't think the Windows one does.  However, while it
could account for the 121 MB vs 182 MB, I am not sure how there can be a 148
MB vs 579 MB difference without either some change in texture assignment or
something (unnecessarily) getting copied for each part.
    Thorsten
